Valheim always says application stopped
OS Name/Version:
Windows Server 2022
Product Name/Version: AMP 2.4.2
Decided to check Valheim after 6 months of not playing it. I had an old instance, removed it. Created a new instance, and started it. When I click update to download the games files… nothing happens to indicate the game is updating. I checked the folders, and it had downloaded and installed Valheim.
When I click start… nothing happens. Task manager shows the server has started up, but AMP never indicates that it’s running. Always says Application Stopped. There’s also no server settings for the game server, no where to set password, etc.
Uninstalled/Reinstalled AMP
Cleared browser cache
Rebooted many times
Install both 32 and 64 bit C++ runtimes: Latest supported Visual C++ Redistributable downloads | Microsoft Learn
That solved the issues! Thanks for the quick reply.
