OS Name/Version:Windows 10 Pro
Product Name/Version:AMP Release "Triton"v2.3.3, built 24/05/2022 15:04
Problem Description: v rising port cannot be replaced
- Step 1
- Step 2
- Step 3
Can you check the port listings in GenericModule.kvp ?
Looks like it updated the legacy ports but not the manifest. I’ll have to look into it.
If you upgrade that instance to the Nightly build, it should automatically fix itself.
Doesn’t look like you’ve switched versions. Run ampinstmgr switch vrising nightly
to switch just that instance over.
Next update, switch it from Nightly to Mainline
