I need export system variable in Docker for activate mods with wine.
export WINEDLLOVERRIDES=“winhttp=n,b”
If this possible? Can you help me?
thks!
thks!
You can add it to App.EnvironmentVariables in GenericModule.kvp for the instance, like this:
App.EnvironmentVariables={"LD_LIBRARY_PATH":"./linux64:%LD_LIBRARY_PATH%","SteamAppId":"1604030","STEAM_COMPAT_DATA_PATH":"{{$FullRootDir}}1493710","STEAM_COMPAT_CLIENT_INSTALL_PATH":"{{$FullRootDir}}1493710","WINEDLLOVERRIDES":"\"winhttp=n,b\""}
But others have tried it on Discord and it hasn’t helped: Discord
Yep, It really doesn’t work ;(
Before I had the server on a docker container and it worked perfectly… any future solution?
Share the docker container where it worked?
Of course, it’s not mine but it works perfect
Thanks! I don’t see anything too crazy in that. It won’t be today, but I can play around and try to get it working.
Maybe try it without the double quoting:
App.EnvironmentVariables={"LD_LIBRARY_PATH":"./linux64:%LD_LIBRARY_PATH%","SteamAppId":"1604030","STEAM_COMPAT_DATA_PATH":"{{$FullRootDir}}1493710","STEAM_COMPAT_CLIENT_INSTALL_PATH":"{{$FullRootDir}}1493710","WINEDLLOVERRIDES":"winhttp=n,b"}
The double quotes are how other guides did it. But the key that’s missing I think is the winecfg and wine prefixes.
Maybe. But in other contexts it is just setting a var, so quotes would be common. AMP should handle that.
I don’t know what’s special about these specifically but everywhere they are quoted when the other vars are not. AMP leaves things unquoted by default.
You’re probably right - it would be the equals sign
Ok, now work BepinEx.
I make this changes in GenericModule.kvp:
App.LinuxCommandLineArgs=–auto-servernum --server-args=’-screen 0 640x480x24:32’ wine64 ./VRisingServer.exe
App.EnvironmentVariables={“LD_LIBRARY_PATH”:"./linux64:%LD_LIBRARY_PATH%",“SteamAppId”:“1604030”,“STEAM_COMPAT_DATA_PATH”:"{{$FullRootDir}}1493710",“STEAM_COMPAT_CLIENT_INSTALL_PATH”:"{{$FullRootDir}}1493710",“WINEDLLOVERRIDES”:“winhttp=n,b”,“WINEARCH”:“win64”}
Now i test mods and tell us if work.
The App.LinuxCommandLineArgs should have been fine. That’s the same thing as it was essentially.
I change in GenericModule.kvp:
App.LinuxCommandLineArgs=–a wine64 ./VRisingServer.exe
and BepinEx Crash, this is log:
[Message: Preloader] BepInEx 6.0.0-be.567 - VRisingServer
[Message: Preloader] BLEEDING EDGE Build #567 from 5d77398a5c3a707ae6de0eb7121d0b8cc5a53b0c at master
[Info : BepInEx] System platform: Windows 7 64-bit
[Info : BepInEx] Process bitness: 64-bit (x64)
[Info : Preloader] Running under Unity v2020.3.31
[Info : Preloader] 0 patcher plugins loaded
[Info : Preloader] 0 assemblies discovered
[Message:AssemblyPatcher] Executing 0 patch(es)
[Message: BepInEx] Chainloader initialized
[Fatal : Preloader] System.ComponentModel.Win32Exception (0x80004005): Failed to reserve address: 0x7F3160200000: Invalid address.
at BepInEx.IL2CPP.Hook.Allocator.WindowsPageAllocator.AllocateChunk (System.IntPtr hint) [0x000f2] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.Allocator.PageAllocator.Allocate (System.IntPtr hint) [0x0008e] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.Allocator.WindowsPageAllocator.Allocate (System.IntPtr hint) [0x00000] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.FastNativeDetour.GenerateTrampolineInner (System.Int32& trampolineLength, System.Int32& jmpLength) [0x00045] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.FastNativeDetour.GenerateTrampoline (System.Reflection.MethodBase signature) [0x0000e] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.FastNativeDetour.GenerateTrampoline[T] () [0x0004a] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Hook.FastNativeDetour.CreateAndApply[T] (System.IntPtr from, T to, T& original, System.Nullable`1[T] callingConvention) [0x0002c] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.IL2CPPChainloader.Initialize (System.String gameExePath) [0x000e4] in <20831d408969472ba3d48658d4a1512f>:0
at BepInEx.IL2CPP.Preloader.Run () [0x00290] in <20831d408969472ba3d48658d4a1512f>:0
