OS Name/Version: Any - But Linux Mint 21.2
Product Name/Version: AMP Release “Deimos” - v2.7, built 05/03/2026 00:24
Per the documentation you are supposed to be able to create a user within an instance. When logging in as that user to that instance url the following recieved:
`This user does not have permission to access this instance. Please ensure that this user has the 'Manage Instance' permission within ADS for this instance. `
As this is inside the instance, there is nowhere to grant that permission that I can find.
- Create Instance as Admin (doesn’t matter but let’s say minecraft)
- Click “Manage Instance” to enter the instance
- Click “Configuration” → “User Management” → “create user”
- Create user and assign password, Enter permissions to start and stop instance for that user under permission manager
- In a separate browser or computer go to the instance’s url
- Log in with newly created user
The Workaround of creating the user at the AMP top level and then giving them permissions that way DOES work, but is not desired for one-off instances.
