Username and password
Hello,
Was wondering if there is a way to request my username and reset my password for the desktop AMP app?
Any help would be greatly appreciated
You can run ampinstmgr resetlogin in the command prompt.
Thank you
Have another issue now, instance name-do i need a server running to beable to change the login?
The instance name is the name of the ADS instance, by default on Windows it’s AMPInstance1-ADS
You AWESOME!!!
Worked like a charm!!!
Thank you Thank you
Now to figure out how to use it :smiley:
Off to youtube I go
Welp, was working on the old amp untill i updated to the newer McMyadmin
Now Im unable to sign in again :frowning:
instance name for linux??
Please enter value for Password
[Info] Stopping Instance: ‘ADS01’
[Info] Stopping instance ADS01…
[Info] Requesting soft-stop…
[Error] IM was unable to execute there requested command.
[Error] FileNotFoundException
[Error] [0] (FileNotFoundException) : Couldn’t find the specified application: kill
[Error] at ModuleShared.Utilities.RunUtility (String ExecutableFile, String Arguments, String WorkingDirectory, ModuleShared.RunningTask MonitorTask, Boolean Hidden, Action1[T] OutputLine) at ModuleShared.Utilities.RunUtility (ModuleShared.Utilities+UnixUtils Utility, String Arguments, String WorkingDirectory, ModuleShared.RunningTask MonitorTask, Boolean Hidden, Action1[T] OutputLine)
at InstanceManagerPlugin.LocalInstanceManager.StopProcInstance (InstanceManagerPlugin.LocalAMPInstance instance)
at InstanceManagerPlugin.LocalInstanceManager.StopInstance (Guid instanceId)
at InstanceManagerCLI.Core.ResetLogin (String InstanceName, String Username, String Password)
at InstanceManagerCLI.Core.ExecuteCommand (Collections.Generic.List1[T] Params, Collections.Generic.Dictionary2[TKey,TValue] Args)
Don’t grave-dig multi-year-old posts please. Kindly make a new post for your specific issue.
Very helpful response as a “staff” member.
I would hope that you as a staff member would know that Google finds these “old” posts as a top result and people come to these forums for an answer and then usually follow up the result with a similar or related question or answer many years later. This whole don’t necro, don’t revive, don’t grave-dig is just lame, unhelpful, and quite frankly, arrogant and off-putting.
A friendly and helpful community helps push your site and product up any recommendation list.
I only ever look at a post date when the answer doesn’t work out and realize it’s out of date.
Sometimes it’s the 10+ year old post that is the most helpful, and a recent response that says it was helpful, worked or even a tweak the next person adds that resolved the issue is very much appreciated.
:chequered_flag:
