Upgrade instance to Advanced
Hi there!
I originally set up my server with pro and recently purchased advanced instead. I changed the key in the instance default and can see that new instances are “advanced” but, how to I upgrade existing instances?
This is all so I can use Analytics.
Thanks!
You can hit the Reactivate All button next to where you input the licence key.
You could also try manually running ampinstmgr reactivate InstanceName01 or ampinstmgr reactivateall in your system’s CLI
(this will stop running instances)
Thanks! I guess I pushed that button but my existing instance still says that I need to upgrade to advanced to see analytics. Do I need to reboot the whole server to see the change?
You might need to clear your browser’s cache for the page
