Updatefirewall don't add rules
OS Name/Version: Debian GNU/Linux 11 (bullseye)
Product Name/Version: AMP Instance Manager v2.6.1.6 built 17/04/2025 03:57
Try to figure out why ampinstmgr updatefirewall do not make any changes to firewall rules.
When I run updatefirewall it looks like everything work good:
[Info/1] AMP Instance Manager v2.6.1.6 built 17/04/2025 03:57
[Info/1] Using iptables firewall.
[Info/1] Adding 25 new firewall rules
[Info/1] Firewall rule to add: TCP/2223 (AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] Firewall rule to add: UDP/12820 (AMP:ADS01:ADSModule.Network.MetricsServerPort)
[Info/1] Firewall rule to add: TCP/2225 (AMP:TS3Server01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] Firewall rule to add: UDP/9987 (AMP:TS3Server01:GenericModule.App.Ports.$Voice)
[Info/1] Firewall rule to add: TCP/30034 (AMP:TS3Server01:GenericModule.App.Ports.$Filetransfer)
[Info/1] Firewall rule to add: TCP/10012 (AMP:TS3Server01:GenericModule.App.Ports.$ServerQueryRAW)
[Info/1] Firewall rule to add: TCP/10023 (AMP:TS3Server01:GenericModule.App.Ports.$ServerQuerySSH)
[Info/1] Firewall rule to add: TCP/10081 (AMP:TS3Server01:GenericModule.App.Ports.$WebQueryHTTP)
[Info/1] Firewall rule to add: TCP/10443 (AMP:TS3Server01:GenericModule.App.Ports.$WebQueryHTTPS)
[Info/1] Firewall rule to add: TCP/2226 (AMP:AVORIONHQ01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] Firewall rule to add: UDP/27003 (AMP:AVORIONHQ01:GenericModule.App.Ports.$QueryPort)
[Info/1] Firewall rule to add: UDP/27020 (AMP:AVORIONHQ01:GenericModule.App.Ports.$SteamQueryPort)
[Info/1] Firewall rule to add: UDP/27021 (AMP:AVORIONHQ01:GenericModule.App.Ports.$SteamPort)
[Info/1] Firewall rule to add: TCP/27015 (AMP:AVORIONHQ01:GenericModule.App.Ports.$RCONPort)
[Info/1] Firewall rule to add: TCP/2224 (AMP:Valheim01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] Firewall rule to add: UDP/2456 (AMP:Valheim01:GenericModule.App.Ports.$ApplicationPort1)
[Info/1] Firewall rule to add: UDP/2457 (AMP:Valheim01:GenericModule.App.Ports.$ApplicationPort2)
[Info/1] Firewall rule to add: TCP/2227 (AMP:RUST01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] Firewall rule to add: UDP/28015 (AMP:RUST01:RustModule.Rust.Port)
[Info/1] Firewall rule to add: UDP/28016 (AMP:RUST01:RustModule.Rust.QueryPort)
[Info/1] Firewall rule to add: TCP/5678 (AMP:RUST01:RustModule.Rust.RconPort)
[Info/1] Firewall rule to add: TCP/28082 (AMP:RUST01:RustModule.Rust.AppPlusPort)
[Info/1] Firewall rule to add: TCP/8081 (AMP:ADS01:Core.Webserver.Port)
[Info/1] Firewall rule to add: TCP/27000 (AMP:AVORIONHQ01:GenericModule.App.Ports.$GamePort)
[Info/1] Firewall rule to add: UDP/27000 (AMP:AVORIONHQ01:GenericModule.App.Ports.$GamePort)
[Info/1] No existing firewall rules to remove
and when next:
ampinstmgr dumpfirewall
[Info/1] No firewall rules to display.
Every time when i use updatefirewall it try to add new rules but without any error.
When I add iptables rule manually then everything works.
How can I debug it to find what cause problem?
Best regards
EDIT:
After few reboots and remove some unused staff, updatefirewall start adding rules.
I don’t know why it not working.
What user were you logged in as when you ran that?
