OS Name/Version: Ubuntu 22.02
Product Name/Version: AMP Instance Manager v2.3.3
Updated and now the web interface crashes and will not start
[02:14:57] [Core Info] : OS: Linux / x86_64
[02:14:57] [Core Info] : CPU: 12th Gen Intel(R) Core(TM) i9-12900K (16C/32T)
[02:14:57] [Core Info] : AMP Instance ID: aa152756-70e0-442b-b808-29defd7ebe6d
[02:14:57] [ModuleLoader Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : ADSModule requests dependency InstanceManagerPlugin...
[02:14:57] [ModuleLoader Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : ADSModule requests dependency SystemUserManagerPlugin...
[02:14:57] [ModuleLoader Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[02:14:57] [Core Info] : Metrics server started OK on port 12820
[02:14:57] [ErrorReporter Error] : Unhandled Exception: Please report this to the AMP developers.
[02:14:57] [ErrorReporter Error] : [Error] --- Begin Exception Data ---
[Error] OS: Linux (x86_64/None)
[Error] Module: ADSModule, Version: AMP 2.3.3.0
[Error] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
[Error] Instance ID: aa152756-70e0-442b-b808-29defd7ebe6d
[Error] AutoMapperMappingException
[Error] [0] (AutoMapperMappingException) : Error mapping types.
Mapping types:
AMPInstanceBase -> InstanceSummary
InstanceManagerPlugin.AMPInstanceBase -> InstanceManagerPlugin.InstanceSummary
Type Map configuration:
Destination Member:
ApplicationEndpoints
[Error] at InstanceManagerPlugin.InstanceSummary.CreateFrom (InstanceManagerPlugin.AMPInstanceBase BaseInstance)
at Linq.Enumerable+SelectEnumerableIterator`2[TSource,TResult].MoveNext ()
at Collections.Generic.List`1[T].AddEnumerable (Collections.Generic.IEnumerable`1[T] enumerable)
at Collections.Generic.List`1[T].InsertRange (Int32 index, Collections.Generic.IEnumerable`1[T] collection)
at Collections.Generic.List`1[T].AddRange (Collections.Generic.IEnumerable`1[T] collection)
at ADSModule.ModuleMain.RefreshInstances ()
at ADSModule.ModuleMain.PostInit ()
at GSMyAdmin.ModuleLoader.RunPostInit ()
at GSMyAdmin.Core.Run ()
at GSMyAdmin.Program.Main ()
[Error] ArgumentException
[Error] [1] (ArgumentException) : An item with the same key has already been added. Key: CustomPort
[Error] at Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, Collections.Generic.InsertionBehavior behavior)
at Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value)
at Linq.Enumerable.ToDictionary[TSource,TKey,TElement] (Collections.Generic.IEnumerable`1[T] source, Func`2[T,TResult] keySelector, Func`2[T,TResult] elementSelector, Collections.Generic.IEqualityComparer`1[T] comparer)
at Linq.Enumerable.ToDictionary[TSource,TKey,TElement] (Collections.Generic.IEnumerable`1[T] source, Func`2[T,TResult] keySelector, Func`2[T,TResult] elementSelector)
at InstanceManagerPlugin.LocalInstanceManager.GetEndpointForInstancePlugin (InstanceManagerPlugin.AMPInstanceBase instance, String Plugin, String FallbackDisplayName, String PreferredDisplayName)
at InstanceManagerPlugin.LocalInstanceManager.GetApplicationEndpoints (InstanceManagerPlugin.AMPInstanceBase instance)
at InstanceManagerPlugin.LocalInstanceManager.GetApplicationEndpoints (Guid instanceId)
at InstanceManagerPlugin.LocalAMPInstance.get_ApplicationEndpoints ()
[Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
[02:14:57] [ErrorReporter Info] : ####################################
[02:14:57] [ErrorReporter Info] : # Self Diagnostics #
[02:14:57] [ErrorReporter Info] : AMP Diagnostics could not establish a solution for this exception.
Update to latest version in ubuntu 22.02
Run ampinstmgr -s ADS01
Run ampinstmgr -i ADS01
Rebooted, Tried Updating again, Shutting Down instance then restartting instance, updating package through apt-get
