Update Panel Problem?
Hello, I have a problem with the panel. It says in the panel that there is an update. But when I want to update it, it always stops here
Then I tried to update via SSH with the command “sudo apt upgrade ampinstmgr” but it says it is uptodate
But the panel still says that i can update it.
What can I do?
Operating system: Debian 11 64 bit
!!!Sorry for my bad englisch!!!
The system tools and the version and the process that runs the webserver are updated independently.
You can run ampinstmgr upgrade InstanceName01 or ampinstmgr upgradeall as the amp Linux user (su -l amp to log into the user)
su -l amp and ampinstmgr upgradeall was the rescue. Thank you
