Field | Value |
Product | AMP ‘Phobos’ v2.6.2.2 (Mainline) |
Virtualization | Docker |
Application | Satisfactory |
Module | GenericModule |
Running in Container | Yes |
Current State | Stopped |
sadly, I’m unable to locate the issue since I can’t find the logs. From my POV the server tries to reach steam CMD and then suddenly fails or so. Maybe this is since satisfactory got an update recently
Edit: basically, the update stops suddenly at step 1 or 2. The update button does always retry the same procedure and does not say, that the update is finished successfully.
This is also noticeable since the server is bugged with the newest version, which is common because then update is missing
- create instance completely new (for the second time already)
- run the instance with start and update always (update failed)
- stopped the instance and retried update w/o any luck
