Update Failure with Minecraft - wont update and stay on neoforge 21.1.213
Disclaimer this is all on Hostinger.
The server is set for neoforge 21.1.213 but when it went to update this time it defaulted to 21.10 and cant find neoforge server type at all on your console
  • the server is set for neoforge 21.1.213 but when it went to update this time it defaulted to 21.10 and cant find neoforge server type at all on your console
  • having too many issues trying to update server manually
  • dont fully understand
oh please tell me you’ve found a solution, cause that’s the same issue I’m having. been running a server using “Allthemods 10 mod pack” and when I tried to play on it last night it stopped working for that exact same reason.
is there a way to manually set the correct one?
First try stopping+starting the MC instance and re-selecting the version. NeoForge has had some issues with their maven lately, which may have buggered with the version selection somewhat.
Then if that doesn’t work: stop the MC instance via the main web panel, click he MC instance’s folder icon, delete the NeoForgeVersionManifest.xml file, then start the MC instance again.
