Update Failure with Minecraft - problem when installing Forge
Product AMP ‘Phobos’ v2.6.0.8 (Mainline)
idfk what is going on i just need help
  • Buy Server To run modpack (modpack uses 4-6gb ram and to be sure i bought 16gb)
  • Select forge (1.12.2 14.23.5.2859) and After create mods file
  • Add mods and do a test run… “ERROR”
  • remove all the files and try again just with forge thinking it could be a problem with mods
  • error again… begins to get frustrated and get some rest to try again later
  • trying again i remove all the files and still doesnt work… confused i try to reboot the entire server even by deleting and creating a new server
  • still doesnt work… confusedx2 i try to run on vanilla and it works… i figure that the forge version could be the problem
  • begin to try out a couple of different forge versions (total of 7 tries) give up and go to write another ticket on the matter
Make sure you have Java 8 selected under Java and Memory, otherwise Forge 1.12.2 won’t run at all
