Update Failure with Minecraft - not installing correctly after launching for the first time
Current State Installing
so i created a new Minecraft java instance but when it starts its gets stuck on installing, waited like an hour and it decided it was too much time so i deleted that and created another which looks like its gonna be the same as the first one
  • create instance
  • launch instance
  • deleted instance after not installing
  • repeated all of it
From the main panel page press the instance’s folder icon, then read its AMP_Logs to see if there’s any hint in there
I fixed it, for whoever has the same problem just install Java 21 in your Server PC and itll fix
