Update Failure with Minecraft - Error when updating minecraft
Product AMP ‘Phobos’ v2.6.1.2 (Mainline)
I recieve the error message “Connection refused (minecraft.azureedge.net:443)”
  • I log in to manage server
  • I clicked the update-button
  • I recieve the error
The Download/Update button? If so you may want to check your instance’s logs
I’m also getting that error.
[02:10:30] [Core:admin Activity/46] : Updating the application.
[02:10:31] [Core:admin Error/40]  : HttpRequestException
[02:10:31] [Core:admin Error/40]  : [0] (HttpRequestException) : Name or service not known (minecraft.azureedge.net:443)
[02:10:31] [Core:admin Error/40]  :    at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
   at Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
   at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   at ModuleShared.Utilities.DownloadFileWithProgressAsync(String url, String filename, RunningTask task, Boolean autoRemoveTask, String UserAgent)
[02:10:31] [Core:admin Error/40]  : SocketException
[02:10:31] [Core:admin Error/40]  : [1] (SocketException) : Name or service not known
[02:10:31] [Core:admin Error/40]  :    at Net.Dns.GetHostEntryOrAddressesCore(String hostName, Boolean justAddresses, AddressFamily addressFamily, Nullable`1 startingTimestamp)
   at Net.Dns.<>c.<GetHostEntryOrAddressesCoreAsync>b__33_0(Object s, Int64 startingTimestamp)
   at Net.Dns.<>c__DisplayClass39_0`1.<RunAsync>b__0(Task <p0>, Object <p1>)
   at ModuleShared.Utilities.<>c.<<-cctor>b__39_1>d.MoveNext()
Would most likely be a DNS or IPv6 issue on that machine, not an AMP issue
Same issue and I can’t reach the minecraft.azureedge.net host on another network I have access to (IPv4 only)
This is AMP Release “Phobos”
v2.6.1.4, built 10/04/2025 12:27
Trying to make a Bedrock server Version: 1.21.3.01 update to current bedrock
[19:55:47] [System Activity/9]    : Authentication attempt for user admin from 127.0.0.1
[19:55:48] [System Activity/9]    : Authentication success
[19:55:55] [Core:admin Activity/10] : Stopping the application.
[19:55:55] [Minecraft:admin Info/10] : Application stop requested
[19:55:55] [INFO]: Server stop requested.
[19:55:55] [INFO]: Stopping server...
[19:55:55] Quit correctly
[19:56:03] [Core:admin Activity/7] : Updating the application.
[19:56:04] [Core:admin Error/13]  : HttpRequestException
[19:56:04] [Core:admin Error/13]  : [0] (HttpRequestException) : Name or service not known (minecraft.azureedge.net:443)
[19:56:04] [Core:admin Error/13]  :    at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
[19:56:04] [Core:admin Error/13]  : SocketException
[19:56:04] [Core:admin Error/13]  : [1] (SocketException) : Name or service not known
[19:56:04] [Core:admin Error/13]  :    at Net.Dns.GetHostEntryOrAddressesCore(String hostName, Boolean justAddresses, AddressFamily addressFamily, Nullable`1 startingTimestamp)
[20:10:49] [Core:admin Activity/29] : Updating the application.
[20:10:49] [Core:admin Error/21]  : HttpRequestException
[20:10:49] [Core:admin Error/21]  : [0] (HttpRequestException) : Name or service not known (minecraft.azureedge.net:443)
[20:10:49] [Core:admin Error/21]  :    at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
[20:10:49] [Core:admin Error/21]  : SocketException
[20:10:49] [Core:admin Error/21]  : [1] (SocketException) : Name or service not known
[20:10:49] [Core:admin Error/21]  :    at Net.Dns.GetHostEntryOrAddressesCore(String hostName, Boolean justAddresses, AddressFamily addressFamily, Nullable`1 startingTimestamp)
# dig minecraft.azureedge.net
; <<>> DiG 9.20.0-2ubuntu3.1-Ubuntu <<>> minecraft.azureedge.net
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 4646
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;minecraft.azureedge.net.       IN      A
;; AUTHORITY SECTION:
azureedge.net.          60      IN      SOA     ns1-06.azure-dns.com. msnhst.microsoft.com. 10001 900 300 604800 60
;; Query time: 10 msec
;; SERVER: 127.0.0.53#53(127.0.0.53) (UDP)
;; WHEN: Sun Apr 13 20:20:44 UTC 2025
;; MSG SIZE  rcvd: 125
Make your own post considering the issue, looks unrelated to the issue the OP is having
