Update Failure with Hytale - Error updating Hytale (/bin/bash failed with exit code 1)
Application Hytale
Error:
This task could not be completed: Running Update Tasks - - State: 3.
CLI error: successfully downloaded “release” patchline (version 2026.01.13-50e69c385)
Archive: 2026.01.13-50e69c385.zip
replace Server/HytaleServer.aot? [y]es, [n]o, [A]ll, [N]one, [r]ename: NULL
(EOF or read error, treating as “[N]one” …)
Yesterday my instance ran fine, now (After hytale updated i think) i can’t start my server anymore.
  • Restarted AMP VM
  • Restarted Hytale instance
  • Successfully created a test instance of hytale, that one is updating: version 2026.01.13-50e69c385
having this same issue if someone has any thoughts it would be appreciated. I get this error when trying to create a new instance.
You shouldn’t get that error with a new instance.
Delete ADS01/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates-main
Then Fetch Latest as per the below
Then create a new instance
