Update Failure with Factorio - try to enable beta with experimental
Application Factorio
try to enable beta with experimental, and server update failed, then it wont start
  • enable beta
  • set experimental branch
  • start server failed
Greelan just fixed this earlier today. Click update on the actual instance (rather than inside it) to get the changes. Then update again inside.
