I have ran start instance for uppdate and keep having schema migrations fail. I have deleted and recreated everything (twice) and it still keeps hanging up on this step.
setup both docker workstation and amp - and did initial system configs for windows per your readme
started intial config after setup on tabs in amp
ran installer and it created image most insstall steps created everything succesfully but getting stuck on database update
Fantastic instructions, ran into both issues as described here and fixes here worked for both issues. These should really be updated into the base set of files for the AMP setup!
