DWisen
1
| Field |
Value |
| Operating System |
Linux - Linux Mint 20.1 on x86_64 |
| Product |
AMP ‘Decadeus’ v2.4.6.0 (Mainline) |
| Virtualization |
None |
| Application |
Call of Duty 4: Modern Warfare |
| Module |
GenericModule |
| Running in Container |
No |
| Current State |
Failed |
Required system-level tool ‘/usr/bin/wine’ does not exist - it may need to be installed manually by the user. Aborting startup.
- Create instance
- Update unstance
- Start instance
- Remove and reinstall instance
Mike
2
This is why it recommeds that docker mode is used when you create the instance. Either use Docker mode or install wine on the host system.
DWisen
3
How would I install in a docker container if i did not select that option during the install of AMP?
getamp installDocker as root
DWisen
5
Awesome, thanks for the replies. I will give these a shot.
system
Closed
6
