Field | Value |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | Docker |
Application | ARK: Survival Ascended |
Module | GenericModule |
Running in Container | Yes |
Current State | Failed |
Output:
root@game-server:/home/administrator# bash -c ‘echo “vm.max_map_count = 16777216” > /etc/sysctl.d/20-max_map_count.conf && sysctl --system’
- Applying /usr/lib/sysctl.d/10-apparmor.conf …
- Applying /etc/sysctl.d/10-bufferbloat.conf …
- Applying /etc/sysctl.d/10-console-messages.conf …
- Applying /etc/sysctl.d/10-ipv6-privacy.conf …
- Applying /etc/sysctl.d/10-kernel-hardening.conf …
- Applying /etc/sysctl.d/10-magic-sysrq.conf …
- Applying /etc/sysctl.d/10-map-count.conf …
- Applying /etc/sysctl.d/10-network-security.conf …
- Applying /etc/sysctl.d/10-ptrace.conf …
- Applying /etc/sysctl.d/10-zeropage.conf …
- Applying /etc/sysctl.d/20-max_map_count.conf …
- Applying /usr/lib/sysctl.d/50-pid-max.conf …
- Applying /usr/lib/sysctl.d/99-protect-links.conf …
- Applying /etc/sysctl.d/99-sysctl.conf …
- Applying /etc/sysctl.conf …
kernel.apparmor_restrict_unprivileged_userns = 1
net.core.default_qdisc = fq_codel
kernel.printk = 4 4 1 7
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.use_tempaddr = 2
kernel.kptr_restrict = 1
kernel.sysrq = 176
vm.max_map_count = 1048576
net.ipv4.conf.default.rp_filter = 2
net.ipv4.conf.all.rp_filter = 2
kernel.yama.ptrace_scope = 1
vm.mmap_min_addr = 65536
kernel.pid_max = 4194304
fs.protected_fifos = 1
fs.protected_hardlinks = 1
fs.protected_regular = 2
fs.protected_symlinks = 1
Output Log Instance;
15:40:16
15:40:17
15:40:18
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1733269577
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 130 msec
OK
force_install_dir “2430930”
15:40:19
15:40:20
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 2430930 validate
15:40:21
IPC function call IClientAppManager::GetUpdateInfo took too long: 47 msec
Error! App ‘2430930’ state is 0x202 after update job.
quit
15:40:22
bash
internet is working fine
- Install Amp on Ubuntuserver 24.04
- Change max_map_count variable
- Create new ASA Instance
- Start ASA Instance
