Update Failure with Application Deployment - Minecraft Java will not install instance
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
Virtualization ProxmoxLXC
I even tried completely wiping the OS and reisntalling AMP. it gives an erorr on instance creation code 3. with a further error of 255.
This task could not be completed: Create instance - Minecraft - State: 3. AMP configuration failed with return code 255.
THANKS for any help.
  • add an instance
  • select minecraft java
  • create instance
