| Product | AMP ‘Phobos’ v2.6.5.2 (Mainline) |
| Virtualization | ProxmoxLXC |
| Module | ADSModule |
| Running in Container | No |
Hello CubeCoders Support,
I am currently unable to run apt update on my Debian 12 (Bookworm) system due to an issue with the CubeCoders APT repository.
APT returns the following error:
E: The repository “https://repo.cubecoders.com
debian/ Release” is no longer signed.
After enabling HTTPS debug output, I can see that:
https://repo.cubecoders.com/debian/InRelease
redirects to https://cdn-repo.c7rs.com/debian/InRelease
The Release file is served correctly
However, Release.gpg returns HTTP 404 (Not Found)
This appears to indicate that the repository is currently not properly signed, as the Release.gpg file is missing.
My current repository configuration:
deb [signed-by=/usr/share/keyrings/repo.cubecoders.com.gpg] https://repo.cubecoders.com/
debian/
Because of this, APT refuses to update the package lists.
Could you please confirm whether:
The repository signing configuration has recently changed?
A new GPG key needs to be installed?
Or if this is a temporary issue on the CDN side?
Thank you for your assistance.
Best regards
- Installed AMP on a Debian 12 (Bookworm) system using the official CubeCoders repository.
- Verified that the repository entry is configured with signed-by=/usr/share/keyrings/repo.cubecoders.com.gpg.
- Executed apt update to refresh package lists.
- APT returns the error: E: The repository “https://repo.cubecoders.com debian/ Release” is no longer signed.
- Enabled HTTPS debug output using apt update -o Debug::Acquire::https=true and observed that: The repository redirects to cdn-repo.c7rs.com The Release file is served The Release.gpg file returns HTTP 404 (Not Found)
