OS Name/Version: Windows 11
Product Name/Version: AMP v2.4.4 running Miencraft Bedrock v1.20
I have a Minecraft server already running on ports 19132/19133 and that server start with no problem at all. Then my second server should run on ports 19147/19148 but that server doesn’t seam to start and never finishes the start sequence and the application status just says ‘Application State: Starting’. Here’s the console output when it’s ‘Starting’:
19:12:09: Console:
[18:12:09] NO LOG FILE! - setting up server logging...
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:948 INFO] Starting Server
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Version: 1.20.12.01
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Session ID: a508682e-e2ed-4765-b249-88f4b78977d6
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Build ID: 16683667
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Branch: r/20_u1
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Commit ID: 262736c074c6357705b05e6a9d5c40b3e5c8fa74
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Configuration: Publish
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:949 INFO] Level Name: world
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:951 INFO] Game mode: 0 Survival
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:951 INFO] Difficulty: 2 NORMAL
[18:12:09] NO LOG FILE! - [2023-07-18 19:12:09:952 INFO] Content logging to console is enabled.
[18:12:10] NO LOG FILE! - [2023-07-18 19:12:10:040 INFO] Opening level 'worlds/world/db'
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:501 INFO] IPv4 supported, port: 19147: Used for gameplay
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:501 INFO] IPv6 supported, port: 19148: Used for gameplay
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] Server started.
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] ================ TELEMETRY MESSAGE ===================
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] Server Telemetry is currently not enabled.
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] Enabling this telemetry helps us improve the game.
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] To enable this feature, add the line 'emit-server-telemetry=true'
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] to the server.properties file in the handheld/src-server directory
[18:12:35] NO LOG FILE! - [2023-07-18 19:12:35:548 INFO] ======================================================
Here’s a screeen shot if the text above is not clear:
UPDATE:
I can now connect to the server, I was just using the wrong ip before. But the ‘Starting’ notifaction still wont go away!
- Tried to delete the instance and create a new one
- I have tried to start the second server first and it started but the first server didn’t
