OS Name/Version: Ubuntu 22.04.4
Product Name/Version: Release “Callisto” v2.5.1.4, built 01/08/2024 21:49
I’ve been trying to start an instance for minecraft using docker to take advantage of the resources I have available to the machine, but any docker instances refuse to launch. If an instance is created for minecraft as a non-docker instance it fires up right away with no issues. I am hosted on Oracle Cloud and followed the recommendations here that are specific to oracle. Docker is installed and the OS and all packages are updated. The deployment log appears to be largely empty without any significant information.
01:49:08
Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
Loaded FileManagerPlugin by CubeCoders Limited
Loaded EmailSenderPlugin by CubeCoders Limited
Loaded WebRequestPlugin by CubeCoders Limited
Loaded CommonCorePlugin by CubeCoders Limited
ADSModule requests dependency InstanceManagerPlugin...
Loaded InstanceManagerPlugin by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin...
Loaded SystemUserManagerPlugin by CubeCoders Limited
01:49:09
Licence Present: AMP Advanced Edition - Lifetime Licence
Loaded steamcmdplugin by CubeCoders Limited
ADS startup complete in 70ms
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
Using keypair with fingerprint g5tlzBlYlFGL9hiFyq5qfsCA4MR3LAnXZEIh/HeMflE=
Websockets are enabled.
Already up to date.
01:49:10
RouterTimer@10Hz with 2 jobs started
Checking for AMP updates...
AMP is up to date.
:ampmin
01:49:41
Application Service port ranges have not been specified, using any available...
01:49:42
Non-managed instances exist, autoconfigure cannot guarantee that the configuration is valid!
01:49:45
Waiting for AMP instance to start...
AMP instance WestCraft01 is now running.
01:49:55
Managed remote instance WestCraft01 at http://127.0.0.1:8081/
Authentication token for ampmin requested by ManageInstance on behalf of ampmin
01:50:11
01:50:12
01:50:25
Stopping instance WestCraft01...
Requesting soft-stop...
Waiting for instance to stop...
01:50:40
Changing setting ADSModule.Defaults.UseDocker to True
01:50:45
Soft-stop request was ignored after waiting for 20 seconds, force stopping...
01:50:55
SIGTERM failed after 10 seconds, killing process...
Instance WestCraft01 has stopped.
01:51:14
docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=AMP_WestCraft01_CONFIGURE": dial unix /var/run/docker.sock: connect: permission denied.
See 'docker run --help'.
Failed to configure new instance WestCraft01 - Current user (amp) isn't part of the docker group. You can fix this by running `usermod -a -G docker amp` as root. If you've already added the user to the group you may need to restart AMP or possibly reboot the system.
01:51:42
01:53:10
01:53:11
ADS startup complete in 78ms
Already up to date.
01:53:12
AMP is up to date.
01:53:16
WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
c161bf12bac47e108563e4a1b6ac6df3a69ae8ba2964d9fb45b1463c2da39762
:ampmin
02:03:43
4017300ebefff825ca03d5b9a8360c0856f037b4f55410da7d6bbc7246897cb1
02:03:50
f817410fc50dc708cf317c0f73ec90cab123f8b8a624328c073bdede30cb067d
02:04:09
3d263e4597c00e87e1ef89f1bcd9a7bc87c053e891cc45e5d7633ed4d2567540
02:05:30
Deleting instance 80344f33-cea3-47bc-a98f-90eaed71ca87
02:06:10
02:06:12
f1cac5dae5d667b5b1c95f2c9bd978948aba5c9cecd70d890156004b264e21c6
02:06:18
bc05b243e3d636d78ab8a94c59f21e372e62ff1f6c93dcd3c5eae32b06557257
02:06:43
b7f886a70291e16dde1c1df12ac711e6e43b5ad8f3abaa4719fe7a447c67b888
02:11:04
4eb3b7b8c059be3d1550ae7c274767b767dc551598023e985d5537d28fa18e7d
- Launch new docker instance for minecraft
- Sits at waiting for application
- Application not running.
Re-install everything, new vm, docker, amp, etc… Also rip hair out.
