Unable to open Web UI
I am getting this error when I click start or update on my Minecraft server:
Could not complete action.
  • Couldn’t determine the URL to fetch an update from. You may need to install this server type manually.
I did not have java installed at first so I did bash <wget -qO- getamp.sh) installJava that I saw from another post and this is the version of java that was installed
After that I just let the server run all night because I saw a different post saying that the error above might just be because the update just takes along time and was not grabbed yet. I tried to start it this morning and it still had the same error above. It would start but be on a continuous installing components cycle and I am not sure what do do now.
Couldn’t determine the URL to fetch an update from usually indicates a network error, or the source for the download is being spotty.
Try setting the Configuration -> AMPCore -> Startup mode to Do nothing, then stop/start the Minecraft instance from the main panel.
Where exactly am I supposed to look? I don’t see AMPCore in configuration in either my Minecraft server or main page.
Might be under System Settings now, if you can’t find it you could try the search bar in the upper right
