Unable to create Java Instance
OS Name/Version: Windows 10 Home 22H2 19045.6466
Product Name/Version: AMP Release “Deimos” v2.7.2, built 17/04/2026 04:49
Problem Description: Hello, I’m just trying to create a Minecraft Java instance. After updating to 2.7.2, I have started getting an " Unable to complete” task error when trying to create an instance.
“Unable to complete task
This task could not be completed: Create instance - Minecraft - State: 3.
AMP configuration failed with return code -2146232797.”
Only with Java version, as I created a Bedrock instance just fine. I get the same line from the pop-up in the console.
  • Step 1: Select Create Instance on the instances page
  • Step 2: select Java Edition (no settings matter for “Start instance on boot” or “after creation”)
  • Step 3: Select Create Instance
Actions taken to resolve so far: AMP reinstallation, turning off the firewall, reinstalling Java, and disabling real-time protection.
Commenting to say that I am also experiencing the exact same issue after updating AMP to 2.7.2, I’m running AMP within a Debian VM.
Similar to Tms92003, I can create other instances for Minecraft Bedrock and ASA for example, only Minecraft Java is failing for me.
"Unable to complete task
AMP configuration failed with return code 255”
An update has been released to address this.
