| Operating System | Windows - Windows 10 Pro on x86_64 |
| Product | AMP ‘Callisto’ v2.5.0.8 (Mainline) |
| Virtualization | None |
| Application | Project Zomboid |
| Module | GenericModule |
| Running in Container | No |
| Current State | Stopped |
Unable to create instance - The core archive failed to dolwoad or unpack: Faile to find a release matching the specified version: Mainline/ - This version may no longe be available to download, you shoudl update to a newer version
- create new instance
- Setting instance
- Instance error
Already tried to delete, reinstall, etc.
Follow steps:
Stop AMP fully by running ampinstmgr stopall in a new command prompt.
Use Task Manager to make sure all AMP.exe and AMPService.exe processes are stopped.
Download a fresh copy of AMPSetup.msi - and run it in Repair mode.
Reboot the system
Run ampinstmgr upgradeall in a command prompt.
Try to running create instance from command line:
[Info] Resolving external IP…
[Notice] AMP Service port ranges have not been specified, using any available…
[Notice] Application Service port ranges have not been specified, using any available…
[Activity] Audit: Unknown/None [CreateInstance] Created instance ADS01 using ADS module on port 8080.
[Error] HttpRequestException
[Error] [0] (HttpRequestException) : Error al enviar la solicitud.
[Error] en ModuleShared.VersionManifest.()
[Error] WebException
[Error] [1] (WebException) : Se ha terminado la conexión: Error inesperado de envío.
[Error] en Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
en Net.Http.HttpClientHandler.GetResponseCallback(IAsyncResult ar)
[Error] IOException
[Error] [2] (IOException) : No se pueden leer los datos de la conexión de transporte: Se ha forzado la interrupción de una conexión existente por el host remoto.
[Error] en Net.Sockets.NetworkStream.BeginWrite(Byte buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state)
en Net.Security.SslState.StartSendBlob(Byte incoming, Int32 count, AsyncProtocolRequest asyncRequest, Boolean renegotiation)
en Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte buffer, AsyncProtocolRequest asyncRequest, Boolean renegotiation)
en Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
en Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
en Net.TlsStream.BeginWrite(Byte buffer, Int32 offset, Int32 size, AsyncCallback asyncCallback, Object asyncState)
en Net.ConnectStream.WriteHeaders(Boolean async)
[Error] SocketException
[Error] [3] (SocketException) : Se ha forzado la interrupción de una conexión existente por el host remoto
[Error] en Net.Sockets.Socket.BeginSend(Byte buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state)
[Error] IOException
[Info] Instance creation failed. Reason: “The core archive failed to download or unpack: Failed to find a release matching the specified version: Mainline/ - This version may no longer be available to download, you should update to a newer version.”
