Unable to access AMP control panel
I originally tried to create tunnel to my Minecraft server using Cloudflared, however once I set it up the AMP game panel and server went offline and I got the listed error below. I attempted to uninstall and reinstall AMP however it failed as I got another error code “AMP install error 1 certbot failed with code 1”, and now I wasn’t able to connect (as oppose to it endlessly loading).
OS Name/Version: Ubuntu Server 24.04.3 LTS
Product Name/Version: AMP Control Pane;
Problem Description: Unable to access AMP control panel all of a sudden following attempting tunnel with Cloudflared
  • Step 1: Create tunnel with Cloudflare
  • Step 2: Site stops working and I get error “amp game panel ReconnectingYour connection to the AMP backend was lost. AMP will attempt to reestablish a connection.If you chose to have your password remembered, you will be logged in automatically without interruption.”
  • Step 3: Attempt to uninstall and reinstall AMP, and now the control panel cant be reached all together
Actions taken to resolve so far: Tried to uninstall and reinstall AMP, as well as removing all sessions
