tModLoader and .Net 8
OS Name/Version:
Fedora 39 Workstation
Amp 2.5.0.8 - 20240502.1
Im creating server instances, installing into docker containers.
It seems that AMP is installing a .Net version 6 with tModLoader into the Docker instance and tModloader was just upgraded to require .Net 8.
Create new instance of tModLoader 1.4+
Start Instance
Try to run server, it wont run, error says its the wrong version of .Net.
I upgraded the .Net on my fedora system to .Net 8, recreated the tModLoader server, and it still installs .Net 6.
Reviewed log files, read error. It states that tModloader requires .Net 8.0.0 and is finding only .Net 6.
Change the version to 8.0.4 under SteamCMD and Updates
Thank you very much. I figured out how to change to 8 as per you directions.
