OS Name/Version: Ubuntu 22.04.1
Product Name/Version: AMP Release “Halimede” v2.4.0.10
I started using Amp to run my teamspeak server(instance running in docker) but it seems it’s not running stable. Every so often(can be every few days, or like today even twice a day) the instance itself seems to crash leaving no trace of anything going wrong in the Logfiles(unless I’m looking into the wrong logs) and the only sign left of something going wrong is what seems to be a mono memory dump(called something like mono_crash.mem.33.7f2d202ea700.blob) and a stopped instance.
The only thing seeming out of order in the TS3 logs themselves is this line:
2022-12-19 20:15:14.351173|WARNING |ServerLibPriv | |The system locale is set to "C" this can cause unexpected behavior. We advice you to repair your locale!
which seems to be caused by a improper locale config within the docker container, though I’m not sure if this has anything to do with the problem.
This are the outputs of within the docker container which shows that locale is set to en_US, which isn’t even present though. I can get rid of that error by manually configuring locales in the container, but that of course isn’t going to survive a restart. This just seems to be an issue with the ampbase docker image and happens in the other non TS3 instances as well without causing problems.
root@ubuntu-dedicated-server:/# locale -a
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_COLLATE to default locale: No such file or directory
C
C.UTF-8
POSIX
locale: Cannot set LC_ALL to default locale: No such file or directory
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
Create a teamspeak instance with docker and wait maybe?
Recreated the instance which didn’t change anything.
