OS Name/Version: Debian 13
Whenever I try to run the teamspeak 6 beta with the http query enabled it keeps saying the port is in use. It does not matter which port I define in the ports for the instance but it keeps happening. I checked using curl and nmap but there is nothing running on the port.
2025-09-30 12:06:43.767843|INFO |ServerLibPriv | |TeamSpeak Server v6.0.0-beta6 (2025-08-20 11:36:38)
2025-09-30 12:06:43.767941|INFO |ServerLibPriv | |SystemInformation: Linux 6.12.43+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.43-1 (2025-08-27) x86_64 Binary: 64bit
2025-09-30 12:06:43.768129|INFO | | |checking database integrity (may take a while)
2025-09-30 12:06:43.770293|INFO |ServerLibPriv | |updated server query admin password
2025-09-30 12:06:43.772815|WARNING |Accounting | |Unable to open /AMP/ts6/server/licensekey.dat
2025-09-30 12:06:43.772877|INFO |Accounting | |Licensing Information
2025-09-30 12:06:43.772887|INFO |Accounting | |licensed to : TeamSpeak Systems GmbH
2025-09-30 12:06:43.772893|INFO |Accounting | |type : No License
2025-09-30 12:06:43.772901|INFO |Accounting | |starting date : Fri Aug 1 00:00:00 2025
2025-09-30 12:06:43.772911|INFO |Accounting | |ending date : Sat Nov 1 00:00:00 2025
2025-09-30 12:06:43.772916|INFO |Accounting | |max virtualservers: 1
2025-09-30 12:06:43.772922|INFO |Accounting | |max slots : 32
2025-09-30 12:06:43.823622|INFO | | |Precomputing puzzle, this may take some seconds...
14:06:44
2025-09-30 12:06:44.634209|INFO | | |Puzzle precompute time: 810
2025-09-30 12:06:44.634479|INFO |FileManager | |listening on 192.168.2.135:30033, [::]:30033
2025-09-30 12:06:44.634987|INFO |Query | |Using a query thread pool size of 2
2025-09-30 12:06:44.635727|INFO |VirtualServer |1 |S3 File Transfer Service enabled
2025-09-30 12:06:44.638861|INFO |VirtualServerBase|1 |listening on 192.168.2.135:9987, [::]:9987
2025-09-30 12:06:44.639896|ERROR | | |could not bind listening tcp socket on 192.168.2.135 : 10081 Address already in use
2025-09-30 12:06:44.639927|CRITICAL|Query | |bind failed on 192.168.2.135:10081, :::10081, 192.168.2.135:10081, :::10081
- Create TeamSpeak 6 instance
- Enable http query
- Error
Changing ports to various numbers (9988, 10081, 10079, 8888)
