Teamspeak 6 not updating
OS Name/Version: Ubuntu 22.04.5 LTS
Product Name/Version: AMP v2.7.2.8, built 08/06/2026 00:16
Problem Description: Teamspeak 6 server won’t update
  • Create Teamspeak 6 instance
  • Wait for new version available
  • Stop server, click update
  • Console shows newest version is downloaded - Actual update won’t start
  • Server won’t restart as you need to update to latest, including the latest license file.
  • Manually entered prefered version in settings (no fix)
  • Manually download latest files on github, overwrite server files using SFTP, restart server.
Log:
2026-06-09 16:44:35.462756|INFO    |ServerLibPriv |   |TeamSpeak Server 6.0.0-beta9 (2026-04-21 12:24:52)
2026-06-09 16:44:35.463220|INFO    |ServerLibPriv |   |SystemInformation: Linux 5.15.0-181-generic #191-Ubuntu SMP Fri May 22 19:09:02 UTC 2026 x86_64 Binary: 64bit
2026-06-09 16:44:35.466247|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
2026-06-09 16:44:35.466678|INFO    |DatabaseQuery |   |dbPlugin version: 3.51.3
2026-06-09 16:44:35.470570|INFO    |DatabaseQuery |   |checking database integrity (may take a while)
2026-06-09 16:44:35.492194|WARNING |Accounting    |   |Unable to open /AMP/ts6/server/licensekey.dat
2026-06-09 16:44:35.492318|CRITICAL|Accounting    |   |The default license has expired. Please use the latest server version.
When clicking the “Update” button for downloading the latest version, the console mentions it was downloaded (6.0.0-beta10). But the actual files are not written/unpacked. After restarting, it reverts back to the previous version (6.0.0-beta9)
I had this issue since 6.0.0-beta7.
Each time i had to update it manually using SFTP. This kinda beats the purpose of the AMP update button.
Your instance is out of date. It was updated for the new download naming/format months ago (a search of this forum would have showed that).
Update it by clicking the down arrow on the instance tile from the main AMP page.
