TeamSpeak 6 not starting after reboot
[18:17:32] [Core Info/1] : Starting AMP version 2.6.2.2 (Phobos), built 06/07/2025 05:38
[18:17:32] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:17:32] [Core Warning/1] : Current time zone is set to Mitteleuropäische Zeit - It is recommended you switch to UTC+0 to avoid time-zone related issues
[18:17:32] [Core Info/1] : OS: Windows / x86_64
[18:17:32] [Core Info/1] : CPU: 13th Gen Intel(R) Core™ i5-1340P (12C/16T)
[18:17:32] [Core Info/1] : RAM: 32316MB
[18:17:32] [Core Info/1] : AMP Instance ID: ddb961f3-f88f-422a-8602-a355e6b80ad0
[18:17:32] [Loader Info/1] : Loaded GenericModule version 2.6.2.2 by CubeCoders Limited
[18:17:32] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[18:17:32] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[18:17:32] [Loader Error/13] : Missing plugin/assembly: MaxMind.Db (C:\AMPDatastore\Instances\TeamSpeak601\Plugins\MaxMind.Db\MaxMind.Db.dll) for
[18:17:32] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[18:17:32] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[18:17:32] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[18:17:32] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[18:17:32] [Core Info/1] : Licence Present: AMP Advanced Edition - Lifetime Licence
[18:17:33] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
[18:17:33] [FileManager Notice/1] : Generated new keypair with fingerprint yW/WXz6zly03TPwB58YXr2wqcsCa8UDvtq1LhkPFL8Y=
[18:17:33] [FileManager Notice/1] : Using keypair with fingerprint yW/WXz6zly03TPwB58YXr2wqcsCa8UDvtq1LhkPFL8Y=
[18:17:33] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2238
[18:17:33] [Webserver Info/1] : Webserver started on http://127.0.0.1:8096
[18:17:33] [Core Info/7] : Checking for AMP updates…
[18:17:33] [Core Info/13] : Startup mode is StartApplication, OneShot.
[18:17:33] [Core Info/13] : AMP is up to date.
[18:17:33] [Core Activity/13] : Authentication attempt for user Locke from 127.0.0.1
[18:17:33] [Core Activity/17] : Authentication success
TeamSpeak 6 v6.0.0-beta5 downloaded
TeamSpeak Server v6.0.0-beta5 (2025-07-10 12:37:11)
(c)TeamSpeak Systems GmbH
Logging to file started (no console logging on Windows)
                  I M P O R T A N T
           Server Query Admin Account created
     loginname= "+++++++++++++++++++++++++++"
     apikey= "++++++++++++++++++++++++++++"
                  I M P O R T A N T
  ServerAdmin privilege key created, please use it to gain
  serveradmin rights for your virtualserver. please
  also check the doc/privilegekey_guide.txt for details.
   token=hxVfBOs4bybOUuTJ+1arY4nZ8T0K4edqniC0aBnk
[18:17:47] [API:Locke Activity/16] : Stopping the application.
[18:18:10] [API:Locke Activity/5] : Starting the application.
TeamSpeak server has crashed. A crashdump has been generated at “C:\AMPDatastore\Instances\TeamSpeak601\ts6\server\crashdumps\tsserver_v6_0_0-beta5_windows_amd64_1752344291.dmp”
[18:18:11] [Generic:Locke Warning/18] : The application stopped unexpectedly. Exit code -1073741819
TeamSpeak server has crashed. A crashdump has been generated at “C:\AMPDatastore\Instances\TeamSpeak601\ts6\server\crashdumps\tsserver_v6_0_0-beta5_windows_amd64_1752344295.dmp”
[18:18:15] [Generic:Locke Warning/18] : The application stopped unexpectedly. Exit code -1073741819
[18:18:15] [Generic:Locke Warning/18] : Application failed to start 2 times, not restarting.
Windows Server 2022 Standard 21H2
after first start up the server wont start again
create Teamspeak Instance
stop the server
start the server
cant read the crashdumps
