OS Name/Version: Windows Server 2019
Product Name/Version:v2.4.0.10
Problem Description: after first install and startup i can join the server but after restart he wont start.
[00:50:17] [Core Info] : Starting AMP version 2.4.0.10 (Halimede), built 27/10/2022 18:15
[00:50:17] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[00:50:17] [Core Warning] : Current time zone is set to Mitteleuropäische Zeit - It is recommended you switch to UTC+0 to avoid time-zone related issues
[00:50:17] [Core Info] : OS: Windows / x86_64
[00:50:17] [Core Info] : CPU: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz (6C/12T)
[00:50:17] [Core Info] : AMP Instance ID: bdd6c6d5-84b0-4c35-8016-04829f16360e
[00:50:17] [ModuleLoader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[00:50:17] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[00:50:17] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : GenericModule requests dependency steamcmdplugin...
[00:50:18] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[00:50:18] [ModuleLoader Info] : GenericModule requests dependency RCONPlugin...
[00:50:18] [ModuleLoader Info] : Loaded RCONPlugin version 1.0.0.1 by CubeCoders Limited
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$Voice
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$Filetransfer
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$ServerQueryRAW
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$ServerQuerySSH
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$WebQueryHTTP
[00:50:18] [Core Error] : Invalid setting node: GenericModule.App.Ports.$WebQueryHTTPS
[00:50:18] [Core Info] : Licence Present: AMP Network Standard Edition (Licenced to Sebastian Bittner)
[00:50:18] [ModuleLoader Notice] : Using keypair with fingerprint o3m8yM9c0fuPiqIqKzcYi8eETMP1loq11E8cPu0QrQM=
[00:50:18] [FileManager Info] : SFTP Server started on 0.0.0.0:2225
[00:50:18] [WebServer Info] : Websockets are enabled.
[00:50:18] [WebServer Info] : Webserver started on http://127.0.0.1:8082
[00:50:18] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[00:50:18] [Core Info] : Checking for AMP updates...
[00:50:18] [Core Info] : AMP is up-to-date.
[00:50:18] [System Activity] : Authentication attempt for user Locke from 127.0.0.1
[00:50:20] [System Activity] : Authentication success
[00:50:22] [System:Locke Activity] : Starting the application.
[00:50:22] [Generic:Locke Info] : Specified executable 'C:\AMPDatastore\Instances\TeamSpeak301\ts3\teamspeak3-server_win64\ts3server.exe does not exist. Updating application...
[00:50:23] [Generic:Locke Info] : Extracting C:\AMPDatastore\Instances\TeamSpeak301\ts3\teamspeak3-server_win64-3.13.7.zip to C:\AMPDatastore\Instances\TeamSpeak301\ts3\...
[00:50:24] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
TeamSpeak 3 Server 3.13.7 (2022-06-20 12:21:53)
(c)TeamSpeak Systems GmbH
Logging to file started (no console logging on Windows)
I M P O R T A N T
Server Query Admin Account created
loginname= "serveradmin", password= "eaacda60c65e48b4afc7312c0d77ceed"
apikey= "BACq8gv3U9maJY1xlT40jM21N3IUhL6rqcgQQKd"
I M P O R T A N T
ServerAdmin privilege key created, please use it to gain
serveradmin rights for your virtualserver. please
also check the doc/privilegekey_guide.txt for details.
token=yFV5xRBEi53EGeqJOK6sXF6m0ie31iPwD6GIqEvD
TS3
Welcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.
error id=256 msg=command\snot\sfound
[00:50:45] [System:Locke Activity] : Stopping the application.
[00:50:54] [System:Locke Activity] : Starting the application.
[00:50:54] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
[00:50:56] [Generic:Locke Warning] : The application stopped unexpectedly. Exit code 0
[00:50:59] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
[00:51:00] [Generic:Locke Warning] : The application stopped unexpectedly. Exit code 0
[00:51:03] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
[00:51:04] [Generic:Locke Warning] : The application stopped unexpectedly. Exit code 0
[00:51:07] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
[00:51:08] [Generic:Locke Warning] : The application stopped unexpectedly. Exit code 0
[00:51:11] [Generic:Locke Info] : Merging config file ./ts3/teamspeak3-server_win64/teamspeak3server.ini (KVP format) using Unicode (UTF-8) encoding.
[00:51:12] [Generic:Locke Warning] : The application stopped unexpectedly. Exit code 0
[00:51:12] [Generic:Locke Warning] : Application failed to start 5 times, not restarting.
install the instance
