| Operating System | Windows - Windows 11 22H2 |
| Product | AMP ‘Phobos’ v2.6.0.10 (Mainline) |
| Virtualization | None |
| Application | Tarkov (Fika Mod) |
| Module | GenericModule |
| Running in Container | No |
| Current State | Idle |
I am unable to edit any parameters in the http.json file from “[instance location]\tarkov\server\SPT_Data\Server\configs” because the file gets overridden on every server start with the default values. As per Fika documentation the file should look like this.
> "ip": "0.0.0.0",
> "port": 6969,
> "backendIp": "WAN IP",
> "backendPort": 6969,
> "webSocketPingDelayMs": 90000,
> "logRequests": true,
> "serverImagePathOverride": {}
However, upon changing the parameters, the file gets reloaded with
> "ip": "<instance local ip>",
> "port": 6969,
> "backendIp": "<instance local ip>",
Adding the ability for the user to define the ip addresses as well as the ports via the Configuration page in the Instance Management would be great!
- Create Instance
- Start the server once so the files get created
- Stop the server
- Go to “[instance location]\tarkov\server\SPT_Data\Server\configs\http.json” and edit the file with the required settings and save the file
- Start the server
- Notice the file gets reverted back to the original values
