Syslog filling with AMP messages
OS Name/Version: Linux Ubuntu 22.04.5 LTS
Product Name/Version: AMP version 2.6.1.4 - 20250410.2
/var/syslog is filling with messages.
Apr 15 17:53:03 gibson ampinstmgr[5396]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:53:03 gibson ampinstmgr[5396]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:53:03 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:53:03 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:54:06 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:54:06 gibson ampinstmgr[5560]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:54:06 gibson ampinstmgr[5560]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:54:07 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:54:07 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:54:34 gibson systemd[1]: Starting AMP Instance Manager Firewall...
Apr 15 17:54:35 gibson systemd[1]: ampfirewall.service: Deactivated successfully.
Apr 15 17:54:35 gibson systemd[1]: Finished AMP Instance Manager Firewall.
Apr 15 17:54:37 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 17:55:08 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 17:55:08 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:55:08 gibson systemd[1]: Starting Check pmlogger instances are running...
Apr 15 17:55:08 gibson systemd[1]: Starting Time & Date Service...
Apr 15 17:55:08 gibson systemd[1]: Started Check pmlogger instances are running.
Apr 15 17:55:08 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 17:55:08 gibson systemd[1]: Started Time & Date Service.
Apr 15 17:55:08 gibson systemd[1]: pmlogger_check.service: Deactivated successfully.
Apr 15 17:55:08 gibson ampinstmgr[5640]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:55:08 gibson ampinstmgr[5640]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:55:09 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:55:09 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:55:09 gibson systemd[1]: amptasks.service: Consumed 1.011s CPU time.
Apr 15 17:55:32 gibson systemd[1]: Starting Check and migrate non-primary pmlogger farm instances...
Apr 15 17:55:32 gibson systemd[1]: Started Check and migrate non-primary pmlogger farm instances.
Apr 15 17:55:32 gibson systemd[1]: pmlogger_farm_check.service: Deactivated successfully.
Apr 15 17:55:38 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 17:56:09 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 17:56:09 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:56:09 gibson systemd[1]: Starting Time & Date Service...
Apr 15 17:56:09 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 17:56:09 gibson systemd[1]: Started Time & Date Service.
Apr 15 17:56:09 gibson ampinstmgr[6162]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:56:09 gibson ampinstmgr[6162]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:56:10 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:56:10 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:56:39 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 17:57:10 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 17:57:10 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:57:10 gibson systemd[1]: Starting Time & Date Service...
Apr 15 17:57:10 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 17:57:10 gibson systemd[1]: Started Time & Date Service.
Apr 15 17:57:10 gibson ampinstmgr[6225]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:57:10 gibson ampinstmgr[6225]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:57:11 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:57:11 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:57:40 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 17:58:02 gibson systemd[1]: Starting Check PMIE instances are running...
Apr 15 17:58:02 gibson systemd[1]: Started Check PMIE instances are running.
Apr 15 17:58:02 gibson systemd[1]: pmie_check.service: Deactivated successfully.
Apr 15 17:58:11 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 17:58:11 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:58:11 gibson systemd[1]: Starting Check and migrate non-primary pmie farm instances...
Apr 15 17:58:11 gibson systemd[1]: Starting Time & Date Service...
Apr 15 17:58:11 gibson systemd[1]: Started Check and migrate non-primary pmie farm instances.
Apr 15 17:58:11 gibson systemd[1]: pmie_farm_check.service: Deactivated successfully.
Apr 15 17:58:11 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 17:58:11 gibson systemd[1]: Started Time & Date Service.
Apr 15 17:58:11 gibson ampinstmgr[6406]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:58:11 gibson ampinstmgr[6406]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:58:12 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:58:12 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:58:12 gibson systemd[1]: amptasks.service: Consumed 1.009s CPU time.
Apr 15 17:59:34 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 17:59:34 gibson systemd[1]: Starting AMP Instance Manager Firewall...
Apr 15 17:59:34 gibson ampinstmgr[6637]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 17:59:34 gibson ampinstmgr[6637]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 17:59:35 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 17:59:35 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 17:59:35 gibson systemd[1]: amptasks.service: Consumed 1.033s CPU time.
Apr 15 17:59:35 gibson systemd[1]: ampfirewall.service: Deactivated successfully.
Apr 15 17:59:35 gibson systemd[1]: Finished AMP Instance Manager Firewall.
Apr 15 17:59:35 gibson systemd[1]: ampfirewall.service: Consumed 1.043s CPU time.
Apr 15 17:59:52 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 18:00:11 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 18:00:11 gibson systemd[1]: Starting Time & Date Service...
Apr 15 18:00:11 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 18:00:11 gibson systemd[1]: Started Time & Date Service.
Apr 15 18:00:41 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 18:00:41 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 18:00:41 gibson ampinstmgr[6724]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 18:00:41 gibson ampinstmgr[6724]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 18:00:42 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 18:00:42 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Apr 15 18:01:11 gibson dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.46' (uid=0 pid=5098 comm="cockpit-bridge --privileged " label="unconfined")
Apr 15 18:01:11 gibson systemd[1]: Starting Time & Date Service...
Apr 15 18:01:11 gibson dbus-daemon[667]: [system] Successfully activated service 'org.freedesktop.timedate1'
Apr 15 18:01:11 gibson systemd[1]: Started Time & Date Service.
Apr 15 18:01:41 gibson systemd[1]: systemd-timedated.service: Deactivated successfully.
Apr 15 18:01:41 gibson systemd[1]: Starting AMP Instance Manager Pending Tasks...
Apr 15 18:01:42 gibson ampinstmgr[6788]: [Info/1] AMP Instance Manager v2.6.1.4 built 10/04/2025 12:28
Apr 15 18:01:42 gibson ampinstmgr[6788]: [Info/1] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Apr 15 18:01:42 gibson systemd[1]: amptasks.service: Deactivated successfully.
Apr 15 18:01:42 gibson systemd[1]: Finished AMP Instance Manager Pending Tasks.
Run AMP
Already tried going to configuration → system settings → Monitoring and Metrics and changing the Logging Level to 030 - Warning.
Even after rebooting the logs start filling again.
That setting in AMP’s interface is for AMP’s own logs. The stuff in the syslog is for AMP’s tasks and ampinstmgr logging
Sloved it… just added the following to the /etc/rsyslog.d/50-default.conf
:msg, contains, "ampinstmgr"  stop
:msg, contains, "ampfirewall"  stop
:msg, contains, "amptasks"  stop
:msg, contains, "AMP"  stop
before
auth,authpriv.*                 /var/log/auth.log
