OS Name/Version: Windows 10 and Windows Server 2022
Product Name/Version: AMP 2.3.3.0
Problem Description: When updated to 2.3.3.0, it gets stucked in updating and then it never comes back. I closed one and now I can’t get it up again. Happened in both Win 10 and also Windows Server 2022
provides syntax highlighting.
Step 1 I clicked update
Step 2 Got stuck updating for an hour
Step 3 Can’t get it back after i manually closed the service and started it again.
If you have any game instances running on Windows and restart ADS it hangs. You’ll need to go to Task Manager and kill any running instances. Then from Terminal run ampinstmgr upgradeall.
Thank you. I always use Linux but I wanted to set up a V Rising server, spend two days setting up a server with Windows Server 2022 and V Rising to now read that you have deployed V Rising for Linux haha, I’m going back to Linux ASAP.
Thanks!
