Stuck Reactivating
OS Name/Version: Windows Server 2022
Product Name/Version: AMP Instance Manager v2.5.1 built 03/07/2024 19:18
I have migrated to a new server. Everything seems to be up and working, except the instances will not start. Looking at the log file, it’s because they are not licensed. When I try to license the system, I get stuck on some instances and it never continues. I get this result via the GUI web portal and command line methods.
Command Line: It gets to one of the instances and says “reactivating instance namehere…” then never continues from that point.
Portal: Configuration → Instance Deployment → License Key → enter key → Reactivate Locl instances. It does the same as the command line and gets hung updating them.
