(un)fortunately the gremlins left overnight and now it seems to be working. i am happy about this, but also annoyed. the logs from when it didn’t work are here incase someone wants to look into it, but it is no longer a critical issue with me.
Log file open, 03/15/22 11:30:10
LogInit: Display: Running engine for game: FactoryGame
LogInit: Display: Project file not found: /home/amp/.ampdata/instances/SatisfactoryTestServer/satisfactory/1690800/FactoryGame/FactoryGame.uproject
LogInit: Display: Attempting to find via project info helper.
LogUProjectInfo: Found projects:
LogPakFile: Display: Found Pak file ../../../FactoryGame/Content/Paks/FactoryGame-LinuxServer.pak attempting to mount.
LogPakFile: Display: Mounting pak file ../../../FactoryGame/Content/Paks/FactoryGame-LinuxServer.pak.
LogPakFile: PakFile PrimaryIndexSize=605610
LogPakFile: PakFile PathHashIndexSize=689135
LogPakFile: PakFile FullDirectoryIndexSize=1914816
LogPakFile: OnPakFileMounted2Time == 0.000002
LogPlatformFile: Using cached read wrapper
LogTaskGraph: Started task graph with 4 named threads and 10 total threads with 3 sets of task threads.
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: -8:00, Platform Override: ''
LogPluginManager: Mounting plugin ReplicationGraph
LogPluginManager: Mounting plugin DTLSHandlerComponent
LogPluginManager: Mounting plugin Wwise
LogPluginManager: Mounting plugin GeometryMode
LogPluginManager: Mounting plugin ApexDestruction
LogPluginManager: Mounting plugin BlueprintStats
LogPluginManager: Mounting plugin OnlineFramework
LogPluginManager: Mounting plugin OnlineSubsystem
LogPluginManager: Mounting plugin OnlineSubsystemUtils
LogPluginManager: Mounting plugin LensDistortion
LogPluginManager: Mounting plugin WindowsDeviceProfileSelector
LogPluginManager: Mounting plugin SteamController
LogPluginManager: Mounting plugin SteamShared
LogPluginManager: Mounting plugin RawInput
LogPluginManager: Mounting plugin MfMedia
LogPluginManager: Mounting plugin OnlineSubsystemSteam
LogPluginManager: Mounting plugin OnlineSubsystemEOS
LogPluginManager: Mounting plugin SignificanceManager
LogPluginManager: Mounting plugin PythonScriptPlugin
LogPluginManager: Mounting plugin EditorScriptingUtilities
LogPluginManager: Mounting plugin EditorTests
LogPluginManager: Mounting plugin FbxAutomationTestBuilder
LogPluginManager: Mounting plugin FunctionalTestingEditor
LogPluginManager: Mounting plugin RuntimeTests
LogPluginManager: Mounting plugin ScreenshotTools
LogPluginManager: Mounting plugin CSSEditorToolsExtension
LogPluginManager: Mounting plugin Paper2D
LogPluginManager: Mounting plugin AISupport
LogPluginManager: Mounting plugin EnvironmentQueryEditor
LogPluginManager: Mounting plugin LightPropagationVolume
LogPluginManager: Mounting plugin AnimationSharing
LogPluginManager: Mounting plugin PluginUtils
LogPluginManager: Mounting plugin PropertyAccessEditor
LogPluginManager: Mounting plugin UObjectPlugin
LogPluginManager: Mounting plugin AssetManagerEditor
LogPluginManager: Mounting plugin FacialAnimation
LogPluginManager: Mounting plugin SpeedTreeImporter
LogPluginManager: Mounting plugin DatasmithContent
LogPluginManager: Mounting plugin VariantManagerContent
LogPluginManager: Mounting plugin AlembicImporter
LogPluginManager: Mounting plugin GeometryCache
LogPluginManager: Mounting plugin AutomationUtils
LogPluginManager: Mounting plugin BackChannel
LogPluginManager: Mounting plugin ChaosClothEditor
LogPluginManager: Mounting plugin ChaosEditor
LogPluginManager: Mounting plugin PlanarCut
LogPluginManager: Mounting plugin GeometryProcessing
LogPluginManager: Mounting plugin EditableMesh
LogPluginManager: Mounting plugin GeometryCollectionPlugin
LogPluginManager: Mounting plugin ProceduralMeshComponent
LogPluginManager: Mounting plugin ChaosSolverPlugin
LogPluginManager: Mounting plugin ChaosNiagara
LogPluginManager: Mounting plugin Niagara
LogPluginManager: Mounting plugin CharacterAI
LogPluginManager: Mounting plugin MotoSynth
LogPluginManager: Mounting plugin PlatformCrypto
LogPluginManager: Mounting plugin ImgMedia
LogPluginManager: Mounting plugin MediaCompositing
LogPluginManager: Mounting plugin MeshPainting
LogPluginManager: Mounting plugin TcpMessaging
LogPluginManager: Mounting plugin UdpMessaging
LogPluginManager: Mounting plugin ActorSequence
LogPluginManager: Mounting plugin LevelSequenceEditor
LogPluginManager: Mounting plugin MatineeToLevelSequence
LogPluginManager: Mounting plugin TemplateSequence
LogPluginManager: Mounting plugin OnlineSubsystemNull
LogPluginManager: Mounting plugin LauncherChunkInstaller
LogPluginManager: Mounting plugin ActorLayerUtilities
LogPluginManager: Mounting plugin AppleImageUtils
LogPluginManager: Mounting plugin AssetTags
LogPluginManager: Mounting plugin AudioCapture
LogPluginManager: Mounting plugin CableComponent
LogPluginManager: Mounting plugin ChunkDownloader
LogPluginManager: Mounting plugin CustomMeshComponent
LogPluginManager: Mounting plugin ExampleDeviceProfileSelector
LogPluginManager: Mounting plugin GooglePAD
LogPluginManager: Mounting plugin LinuxDeviceProfileSelector
LogPluginManager: Mounting plugin PhysXVehicles
LogPluginManager: Mounting plugin RuntimePhysXCooking
LogPluginManager: Mounting plugin SoundFields
LogPluginManager: Mounting plugin Synthesis
LogPluginManager: Mounting plugin AudioSynesthesia
LogInit: Using libcurl 7.65.3-DEV
LogInit: - built for x86_64-unknown-linux-gnu
LogInit: - supports SSL with OpenSSL/1.1.1c
LogInit: - supports HTTP deflate (compression) using libz 1.2.8
LogInit: - other features:
LogInit: CURL_VERSION_SSL
LogInit: CURL_VERSION_LIBZ
LogInit: CURL_VERSION_IPV6
LogInit: CURL_VERSION_ASYNCHDNS
LogInit: CURL_VERSION_LARGEFILE
LogInit: CURL_VERSION_TLSAUTH_SRP
LogInit: CurlRequestOptions (configurable via config and command line):
LogInit: - bVerifyPeer = true - Libcurl will verify peer certificate
LogInit: - bUseHttpProxy = false - Libcurl will NOT use HTTP proxy
LogInit: - bDontReuseConnections = false - Libcurl will reuse connections
LogInit: - MaxHostConnections = 16 - Libcurl will limit the number of connections to a host
LogInit: - LocalHostAddr = Default
LogInit: - BufferSize = 65536
LogOnline: OSS: Creating online subsystem instance for: EOS
LogOnline: OSS: FOnlineSubsystemEOS: Init success.
LogSteamShared: Display: Loading Steam SDK 1.47
LogCore: Warning: dlopen failed: /home/amp/.ampdata/instances/SatisfactoryTestServer/satisfactory/1690800/Engine/Binaries/Linux/libsteam_api.so: cannot open shared object file: No such file or directory
LogSteamShared: Warning: Could not find system one, loading bundled libsteam_api.so.
LogSteamShared: Display: Loaded libsteam_api.so at 0x1029c10
LogSteamShared: Steam SDK Loaded!
LogOnline: OSS: Creating online subsystem instance for: STEAM
LogGenericPlatformMisc: Error: SetEnvironmentVar not implemented for this platform: SteamAppId = 526870
LogSteamShared: Warning: Steam Dedicated Server API failed to initialize.
LogOnline: STEAM: [AppId: 0] Game Server API initialized 0
LogOnline: Warning: STEAM: Failed to initialize Steam, this could be due to a Steam server and client running on the same machine. Try running with -NOSTEAM on the cmdline to disable.
LogOnline: Display: STEAM: OnlineSubsystemSteam::Shutdown()
LogOnline: Warning: STEAM: Steam API failed to initialize!
LogOnline: OSS: Unable to create OnlineSubsystem module STEAM
LogOnline: OSS: TryLoadSubsystemAndSetDefault: Loaded subsystem for module [EOS]
LogInit: Build: ++FactoryGame+rel-early-access-CL-177909
LogInit: Engine Version: 4.26.1-177909+++FactoryGame+rel-early-access
LogInit: Compatible Engine Version: 4.26.1-177909+++FactoryGame+rel-early-access
LogInit: Net CL: 177909
LogInit: OS: GenericOSVersionLabel (GenericOSSubVersionLabel), CPU: 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz, GPU: GenericGPUBrand
LogInit: Compiled (64-bit): Jan 31 2022 15:06:02
LogInit: Compiled with Clang: 10.0.1 (https://github.com/llvm/llvm-project ef32c611aa214dea855364efd7ba451ec5ec3f74)
LogInit: Build Configuration: Shipping
LogInit: Branch Name: ++FactoryGame+rel-early-access
LogInit: Command Line: -log -unattended -MultiHome=0.0.0.0 ?listen -Port=7777 -BeaconPort=15000 -ServerQueryPort=15777
LogInit: Base Directory: /home/amp/.ampdata/instances/SatisfactoryTestServer/satisfactory/1690800/Engine/Binaries/Linux/
LogInit: Allocator: binned2
LogInit: Installed Engine Build: 0
LogInit: Launcher File: /home/amp/.ampdata/instances/SatisfactoryTestServer/satisfactory/1690800/launcher_id
LogInit: Launcher ID: steam
LogInit: Launcher Artifact:
LogInit: Presizing for max 2097152 objects, including 1 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
LogStreaming: Display: Async Loading initialized: Event Driven Loader: true, Async Loading Thread: true, Async Post Load: true
LogInit: Object subsystem initialized
[2022.03.15-18.30.10:593][ 0]LogLinux: Selected Device Profile: [LinuxServer]
[2022.03.15-18.30.10:593][ 0]LogInit: Applying CVar settings loaded from the selected device profile: [LinuxServer]
[2022.03.15-18.30.10:593][ 0]LogHAL: Display: Platform has ~ 4 GB [4078239744 / 4294967296 / 4], which maps to Smallest [LargestMinGB=32, LargerMinGB=12, DefaultMinGB=8, SmallerMinGB=6, SmallestMinGB=0)
[2022.03.15-18.30.10:593][ 0]LogInit: Going up to parent DeviceProfile [Linux]
[2022.03.15-18.30.10:593][ 0]LogInit: Going up to parent DeviceProfile []
[2022.03.15-18.30.10:593][ 0]LogInit: Unix hardware info:
[2022.03.15-18.30.10:593][ 0]LogInit: - we are the first instance of this executable
[2022.03.15-18.30.10:593][ 0]LogInit: - this process' id (pid) is 4471, parent process' id (ppid) is 4349
[2022.03.15-18.30.10:593][ 0]LogInit: - we are not running under debugger
[2022.03.15-18.30.10:593][ 0]LogInit: - machine network name is 'ubuntu'
[2022.03.15-18.30.10:593][ 0]LogInit: - user name is 'amp' (amp)
[2022.03.15-18.30.10:593][ 0]LogInit: - we're logged in locally
[2022.03.15-18.30.10:593][ 0]LogInit: - we're running without rendering
[2022.03.15-18.30.10:593][ 0]LogInit: - CPU: GenuineIntel '11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz' (signature: 0xA0671)
[2022.03.15-18.30.10:593][ 0]LogInit: - Number of physical cores available for the process: 2
[2022.03.15-18.30.10:593][ 0]LogInit: - Number of logical cores available for the process: 2
[2022.03.15-18.30.10:593][ 0]LogInit: - Cache line size: 64
[2022.03.15-18.30.10:593][ 0]LogInit: - Memory allocator used: binned2
[2022.03.15-18.30.10:593][ 0]LogInit: - This binary is optimized with LTO: no, PGO: no, instrumented for PGO data collection: no
[2022.03.15-18.30.10:593][ 0]LogInit: - This is a licensee build.
[2022.03.15-18.30.10:593][ 0]LogCore: Benchmarking clocks:
[2022.03.15-18.30.10:593][ 0]LogCore: - CLOCK_MONOTONIC (id=1) can sustain 62107303 (62107K, 62M) calls per second without zero deltas.
[2022.03.15-18.30.10:593][ 0]LogCore: - CLOCK_MONOTONIC_RAW (id=4) can sustain 65957756 (65958K, 66M) calls per second without zero deltas.
[2022.03.15-18.30.10:593][ 0]LogCore: - CLOCK_MONOTONIC_COARSE (id=6) can sustain 267889122 (267889K, 268M) calls per second with 99.999903% zero deltas.
[2022.03.15-18.30.10:593][ 0]LogCore: Selected clock_id 4 (CLOCK_MONOTONIC_RAW) since it is the fastest support clock without zero deltas.
[2022.03.15-18.30.10:593][ 0]LogInit: Unix-specific commandline switches:
[2022.03.15-18.30.10:593][ 0]LogInit: -ansimalloc - use malloc()/free() from libc (useful for tools like valgrind and electric fence)
[2022.03.15-18.30.10:593][ 0]LogInit: -jemalloc - use jemalloc for all memory allocation
[2022.03.15-18.30.10:593][ 0]LogInit: -binnedmalloc - use binned malloc for all memory allocation
[2022.03.15-18.30.10:593][ 0]LogInit: -filemapcachesize=NUMBER - set the size for case-sensitive file mapping cache
[2022.03.15-18.30.10:593][ 0]LogInit: -useksm - uses kernel same-page mapping (KSM) for mapped memory (OFF)
[2022.03.15-18.30.10:593][ 0]LogInit: -ksmmergeall - marks all mmap'd memory pages suitable for KSM (OFF)
[2022.03.15-18.30.10:593][ 0]LogInit: -preloadmodulesymbols - Loads the main module symbols file into memory (OFF)
[2022.03.15-18.30.10:593][ 0]LogInit: -sigdfl=SIGNAL - Allows a specific signal to be set to its default handler rather then ignoring the signal
[2022.03.15-18.30.10:593][ 0]LogInit: -httpproxy=ADDRESS:PORT - redirects HTTP requests to a proxy (only supported if compiled with libcurl)
[2022.03.15-18.30.10:593][ 0]LogInit: -reuseconn - allow libcurl to reuse HTTP connections (only matters if compiled with libcurl)
[2022.03.15-18.30.10:593][ 0]LogInit: -virtmemkb=NUMBER - sets process virtual memory (address space) limit (overrides VirtualMemoryLimitInKB value from .ini)
[2022.03.15-18.30.10:593][ 0]LogInit: - Physical RAM available (not considering process quota): 4 GB (3889 MB, 3982656 KB, 4078239744 bytes)
[2022.03.15-18.30.10:593][ 0]LogInit: - VirtualMemoryAllocator pools will grow at scale 1.4
[2022.03.15-18.30.10:593][ 0]LogInit: - MemoryRangeDecommit() will will evict the memory from RAM (re-run with -novmapoolevict to change)
[2022.03.15-18.30.10:606][ 0]LogInit: Physics initialised using underlying interface: PhysX
[2022.03.15-18.30.10:606][ 0]LogInit: Overriding language with engine language configuration option (en-US-Posix).
[2022.03.15-18.30.10:606][ 0]LogInit: Overriding language with engine locale configuration option (en-US-Posix).
[2022.03.15-18.30.10:609][ 0]LogTextLocalizationResource: LocRes '../../../Engine/Content/Localization/Engine/en-US-POSIX/Engine.locres' could not be opened for reading!
[2022.03.15-18.30.10:609][ 0]LogTextLocalizationResource: LocRes '../../../Engine/Plugins/Online/OnlineFramework/Content/Localization/OnlineFramework/en-US-POSIX/OnlineFramework.locres' could not be opened for reading!
[2022.03.15-18.30.10:609][ 0]LogTextLocalizationResource: LocRes '../../../Engine/Plugins/Online/OnlineSubsystem/Content/Localization/OnlineSubsystem/en-US-POSIX/OnlineSubsystem.locres' could not be opened for reading!
[2022.03.15-18.30.10:609][ 0]LogTextLocalizationResource: LocRes '../../../Engine/Plugins/Online/OnlineSubsystemUtils/Content/Localization/OnlineSubsystemUtils/en-US-POSIX/OnlineSubsystemUtils.locres' could not be opened for reading!
[2022.03.15-18.30.10:609][ 0]LogTextLocalizationResource: LocRes '../../../Engine/Plugins/Online/OnlineSubsystemSteam/Content/Localization/OnlineSubsystemSteam/en-US-POSIX/OnlineSubsystemSteam.locres' could not be opened for reading!
[2022.03.15-18.30.10:622][ 0]LogRendererCore: Ray tracing is disabled. Reason: r.RayTracing=0.
[2022.03.15-18.30.10:628][ 0]LogInit: Overriding language with engine language configuration option (en-US-Posix).
[2022.03.15-18.30.10:628][ 0]LogInit: Overriding language with engine locale configuration option (en-US-Posix).
[2022.03.15-18.30.10:632][ 0]LogTextLocalizationResource: LocRes '../../../FactoryGame/Content/Localization/Game/en/Game.locres' could not be opened for reading!
[2022.03.15-18.30.10:636][ 0]LogTextLocalizationManager: Compacting localization data took 0.83ms
[2022.03.15-18.30.10:706][ 0]LogAssetRegistry: FAssetRegistry took 0.0626 seconds to start up
[2022.03.15-18.30.10:740][ 0]LogStreaming: Display: FlushAsyncLoading: 1 QueuedPackages, 0 AsyncPackages
[2022.03.15-18.30.10:740][ 0]LogPackageLocalizationCache: Processed 23 localized package path(s) for 2 prioritized culture(s) in 0.000078 seconds
[2022.03.15-18.30.10:740][ 0]LogPakFile: New pak file ../../../FactoryGame/Content/Paks/FactoryGame-LinuxServer.pak added to pak precacher.
[2022.03.15-18.30.10:741][ 0]LogLinux: Selected Device Profile: [LinuxServer]
[2022.03.15-18.30.10:741][ 0]LogInit: Active device profile: [0x7f2b635e9040][0x7f2b84f36280 49] LinuxServer
[2022.03.15-18.30.10:743][ 0]LogInit: Profiles: [0x7f2b635e91c0][0x7f2b84f37630 49] Linux, [0x7f2b635e9040][0x7f2b84f36280 49] LinuxServer,
[2022.03.15-18.30.10:749][ 0]LogSerialization: Display: AllowBulkDataInIoStore: 'true'
[2022.03.15-18.30.10:750][ 0]LogNetVersion: FactoryGame 1.0.0, NetCL: 177909, EngineNetVer: 16, GameNetVer: 0 (Checksum: 2886079025)
[2022.03.15-18.30.10:982][ 0]LogActor: Warning: SetReplicates called on non-initialized actor Default__FGSimulatedWheeledVehicle. Directly setting bReplicates is the correct procedure for pre-init actors.
[2022.03.15-18.30.11:051][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/Factory/Doors/NS_DoorClose_01.NS_DoorClose_01 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 16MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 32MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 48MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 64MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 80MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 96MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 112MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 128MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 144MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 160MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 176MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 192MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 208MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 224MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 240MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 256MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 272MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 288MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 304MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 320MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 336MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 352MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 368MB
[2022.03.15-18.30.12:221][ 0]LogPakFile: Precache HighWater 384MB
[2022.03.15-18.30.12:221][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/World/AmbientLife/Flies/NS_Fireflies_01.NS_Fireflies_01 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:221][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/World/AmbientLife/Bats/NS_Bats_01.NS_Bats_01 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:221][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/Misc/Event/Christmas/NS_Fireworks_02.NS_Fireworks_02 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:221][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/Misc/Event/Christmas/NS_Fireworks_01.NS_Fireworks_01 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:221][ 0]LogNiagara: Warning: NiagaraSystem /Game/FactoryGame/VFX/Misc/Event/Christmas/NS_Fireworks_03.NS_Fireworks_03 IsReadyToRunInternal() failed due to missing SystemScript. Spawn[<none>] Update[<none>]
[2022.03.15-18.30.12:327][ 0]GameAnalyticsModule: Display: GameAnalyticsModule has started!
[2022.03.15-18.30.12:327][ 0]LogStreaming: Warning: Failed to read file '../../../FactoryGame/Saved/SaveGames/GameAnalytics.sav' error.
[2022.03.15-18.30.12:400][ 0]LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
[2022.03.15-18.30.12:421][ 0]LogUObjectArray: 57572 objects as part of root set at end of initial load.
[2022.03.15-18.30.12:421][ 0]LogUObjectArray: 2 objects are not in the root set, but can never be destroyed because they are in the DisregardForGC set.
[2022.03.15-18.30.12:421][ 0]LogUObjectAllocator: 17571520 out of 0 bytes used by permanent object pool.
[2022.03.15-18.30.12:421][ 0]LogUObjectArray: CloseDisregardForGC: 57572/57572 objects in disregard for GC pool
[2022.03.15-18.30.12:422][ 0]LogEngine: Initializing Engine...
[2022.03.15-18.30.12:422][ 0]LogStats: UGameplayTagsManager::InitializeManager - 0.000 s
[2022.03.15-18.30.12:438][ 0]LogInit: Initializing FReadOnlyCVARCache
[2022.03.15-18.30.12:438][ 0]LogNetVersion: Set ProjectVersion to 0.0.1.0. Version Checksum will be recalculated on next use.
[2022.03.15-18.30.12:438][ 0]LogInit: Texture streaming: Disabled
[2022.03.15-18.30.12:454][ 0]LogOnline: OSS: Creating online subsystem instance for: STEAM
[2022.03.15-18.30.12:454][ 0]LogGenericPlatformMisc: Error: SetEnvironmentVar not implemented for this platform: SteamAppId = 526870
[2022.03.15-18.30.12:455][ 0]LogSteamShared: Warning: Steam Dedicated Server API failed to initialize.
[2022.03.15-18.30.12:455][ 0]LogOnline: STEAM: [AppId: 0] Game Server API initialized 0
[2022.03.15-18.30.12:455][ 0]LogOnline: Warning: STEAM: Failed to initialize Steam, this could be due to a Steam server and client running on the same machine. Try running with -NOSTEAM on the cmdline to disable.
[2022.03.15-18.30.12:455][ 0]LogOnline: Display: STEAM: OnlineSubsystemSteam::Shutdown()
[2022.03.15-18.30.12:455][ 0]LogOnline: Warning: STEAM: Steam API failed to initialize!
[2022.03.15-18.30.12:455][ 0]LogOnline: OSS: Creating online subsystem instance for: STEAM
[2022.03.15-18.30.12:455][ 0]LogGenericPlatformMisc: Error: SetEnvironmentVar not implemented for this platform: SteamAppId = 526870
[2022.03.15-18.30.12:455][ 0]LogServer: Warning: Packet routing is not compatible with the multihome startup parameter. Disabling packet routing.
[2022.03.15-18.30.12:457][ 0]LogGame: MaxNumBackupsaves: 25
[2022.03.15-18.30.12:457][ 0]GameAnalyticsModule: Display: Loaded GUID 2855B315-9F5C-4865-8064-2F266E64F585
[2022.03.15-18.30.12:457][ 0]LogOnline: Warning: OSS: [EOS SDK | Plugin] Begin Player Session...
[2022.03.15-18.30.12:457][ 0]LogInit: Display: Game Engine Initialized.
[2022.03.15-18.30.12:458][ 0]LogNetVersion: Set ProjectVersion to ++FactoryGame+rel-early-access-CL-177909. Version Checksum will be recalculated on next use.
[2022.03.15-18.30.12:458][ 0]LogConsoleResponse: Display: Can't switch to RHI thread mode when we are not running a multithreaded renderer.
[2022.03.15-18.30.12:458][ 0]LogConsoleResponse: Display: RHIThread is disabled.
[2022.03.15-18.30.12:459][ 0]LogInit: OnPostEngineInit has been broadcasted successfully.
[2022.03.15-18.30.12:461][ 0]LogInit: Display: Starting Game.
[2022.03.15-18.30.12:461][ 0]LogNet: Browse: /Game/FactoryGame/Map/DedicatedserverEntry?Name=Player
[2022.03.15-18.30.12:461][ 0]LogLoad: LoadMap: /Game/FactoryGame/Map/DedicatedserverEntry?Name=Player
[2022.03.15-18.30.12:461][ 0]LogWorld: BeginTearingDown for /Temp/Untitled_0
[2022.03.15-18.30.12:462][ 0]LogWorld: UWorld::CleanupWorld for Untitled, bSessionEnded=true, bCleanupResources=true
[2022.03.15-18.30.12:470][ 0]LogUObjectHash: Compacting FUObjectHashTables data took 7.50ms
[2022.03.15-18.30.12:526][ 0]LogAIModule: Creating AISystem for world DedicatedserverEntry
[2022.03.15-18.30.12:527][ 0]LogLoad: Game class is 'BP_GameModeMenu_C'
[2022.03.15-18.30.12:528][ 0]LogReplicationGraph: Display: SetActorDiscoveryBudget set to 20 kBps (5333 bits per network tick).
[2022.03.15-18.30.12:529][ 0]LogNetCore: DDoS detection status: detection enabled: 0 analytics enabled: 0
[2022.03.15-18.30.12:530][ 0]LogInit: BSD IPv4/6: Socket queue. Rx: 262144 (config 131072) Tx: 262144 (config 131072)
[2022.03.15-18.30.12:530][ 0]LogNet: Created socket for bind address: 0.0.0.0 on port 7777
[2022.03.15-18.30.12:530][ 0]PacketHandlerLog: Loaded PacketHandler component: DTLSHandlerComponent ()
[2022.03.15-18.30.12:530][ 0]PacketHandlerLog: Loaded PacketHandler component: Engine.EngineHandlerComponentFactory (StatelessConnectHandlerComponent)
[2022.03.15-18.30.12:530][ 0]LogNet: GameNetDriver EOSNetDriver_2147482558 IpNetDriver listening on port 7777
[2022.03.15-18.30.12:530][ 0]LogWorld: Bringing World /Game/FactoryGame/Map/DedicatedserverEntry.DedicatedserverEntry up for play (max tick rate 30) at 2022.03.15-11.30.12
[2022.03.15-18.30.12:538][ 0]LogWorld: Bringing up level for play took: 0.007391
[2022.03.15-18.30.12:538][ 0]LogGameMode: Display: Match State Changed from EnteringMap to WaitingToStart
[2022.03.15-18.30.12:538][ 0]LogGameState: Match State Changed from EnteringMap to WaitingToStart
[2022.03.15-18.30.12:539][ 0]LogReplicationGraph: Display: SetActorDiscoveryBudget set to 20 kBps (5333 bits per network tick).
[2022.03.15-18.30.12:539][ 0]LogNetCore: DDoS detection status: detection enabled: 0 analytics enabled: 0
[2022.03.15-18.30.12:539][ 0]LogInit: BSD IPv4/6: Socket queue. Rx: 262144 (config 131072) Tx: 262144 (config 131072)
[2022.03.15-18.30.12:539][ 0]LogNet: Created socket for bind address: 0.0.0.0 on port 15000
[2022.03.15-18.30.12:539][ 0]PacketHandlerLog: Loaded PacketHandler component: DTLSHandlerComponent ()
[2022.03.15-18.30.12:539][ 0]PacketHandlerLog: Loaded PacketHandler component: Engine.EngineHandlerComponentFactory (StatelessConnectHandlerComponent)
[2022.03.15-18.30.12:539][ 0]LogNet: IpNetDriver_2147482541 IpNetDriver_2147482541 IpNetDriver listening on port 15000
[2022.03.15-18.30.12:539][ 0]LogLoad: Took 0.078260 seconds to LoadMap(/Game/FactoryGame/Map/DedicatedserverEntry)
[2022.03.15-18.30.12:539][ 0]LogInit: Display: Engine is initialized. Leaving FEngineLoop::Init()
[2022.03.15-18.30.12:539][ 0]LogLoad: (Engine Initialization) Total time: 2.18 seconds
[2022.03.15-18.30.12:575][ 1]LogOnline: Warning: OSS: EOSSDK-LogEOSP2P: NAT Detection failed, unable to resolve host
[2022.03.15-18.30.13:049][ 15]LogOnline: Warning: OSS: EOSSDK-LogEOSAnalytics: EOS SDK Analytics disabled for route [1].
[2022.03.15-18.30.13:586][ 31]LogOnline: Warning: OSS: EOSSDK-LogEOSEcom: Purchase flow is disabled due to overlay setup failure (EOS_NotConfigured).
