Stuck in "AMP Recovery Mode"
OS Name/Version: Windows 10 Pro version 10.0.19045 Build 19045
Product Name/Version: AMP Instance Manager v2.6.3.0
Unable to get into AMP Instance Manager, keeps going to a page that says “AMP is not currently running”. It seems like I also can’t launch the console via cmd, because it closes immediately upon running the command in CMD.
  • Launch AMP Instance Manager
  • Browser opens in “AMP Recovery Mode”
  • Continues to keep trying to reconnect
  • Repaired installed
  • Reinstalled
  • Restarted instance via cmd ampinstmgr restart ads01
  • Reset AMP user password ampinstmgr resetlogin
  • Restarted AMP-ADS01 service
  • Started with command ampinstmgr startall
  • Ran windows updates
  • Many reboots
Providing recent logs below
[20:59:42] [Core Info/1]          : Starting AMP version 2.6.3.0 (Phobos), built 26/09/2025 12:09
[20:59:42] [Core Info/1]          : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[20:59:42] [Core Warning/1]       : Current time zone is set to Central Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[20:59:42] [Core Info/1]          : OS: Windows / x86_64
[20:59:42] [Core Info/1]          : CPU: AMD Ryzen 9 3900X 12-Core Processor (12C/24T)
[20:59:42] [Core Info/1]          : RAM: 65462MB
[20:59:42] [Core Info/1]          : AMP Instance ID: a338cf60-0bfa-41e7-89cf-f085030f0a2d
[20:59:43] [Loader Info/1]        : Loaded ADSModule version 2.6.3 by CubeCoders Limited
[20:59:43] [Loader Info/1]        : Loaded FileManagerPlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : Loaded EmailSenderPlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : Loaded WebRequestPlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : Loaded WebhookPlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : Loaded CommonCorePlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : ADSModule requests dependency InstanceManagerPlugin...
[20:59:43] [Loader Info/1]        : Loaded InstanceManagerPlugin by CubeCoders Limited
[20:59:43] [Loader Info/1]        : ADSModule requests dependency SystemUserManagerPlugin...
[20:59:43] [Loader Info/1]        : Loaded SystemUserManagerPlugin by CubeCoders Limited
[20:59:43] [Core Info/1]          : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
