Stuck and nothing happen when Installing AMP on Debian 13
OS Name/Version: Debian 13
Problem Description: Run the installation but nothing happen.
luxxert@Luxxump:~$ sudo su -
[sudo] password for luxxert:
root@Luxxump:~# bash <(curl -fsSL getamp.sh)
Please wait while GetAMP examines your system and network configuration...
 - Checking installed packages...
 - Checking environment...
 - Checking network configuration...
  • Step 1 bash <(curl -fsSL getamp.sh)
  • Step 2
  • Step 3
Actions taken to resolve so far: Restart the pc but still same thing happen.
If the installation hangs on Checking network configuration..., then something’s probably wrong with your network configuration! :slight_smile:
Check your DNS and maybe disable IPv6 for the time being.
what do i do after checking my DNS? and i did some google get the command to disable the IPv6 and tried but it doesnt give the result same as in any site.
my debian vesion is 13.6
could you guide me?
