Startup Issue with Windrose - Windrose: Wine not Implemented
Product AMP ‘Deimos’ v2.7.2.2 (Mainline)
Application Windrose
Current State Starting
I am trying to play on my Windrose server that has been working for days now, al of a sudden ‘wine’ is not implementing. Starting the instance is not working
  • Delete .wine folder and recreate on startup
  • Ask assistance from Kodee
  • Checked Windrose Forums for information
I’m also having similar issues, it was working just yesterday, and now today the server cant start also refuses to update.
Edit:
After some testing, it seems to be all of my servers that use Wine that’s not working.
Servers i’ve tested:
7 Days to die (doesn’t use Wine) = Works with no issue
Palworld (uses Wine) = wine: socket : Function not implemented
Space Engineers (uses Wine) = wine: socket : Function not implemented
Windrose (uses Wine) = wine: socket : Function not implemented
┃ Key                  ┃ Value                                 ┃
┃ Operating System     ┃ Linux - Debian GNU/Linux 13 on x86_64 ┃
┃ Product              ┃ AMP 'Deimos' v2.7.2.0 (Mainline)      ┃
┃ Virtualization       ┃ VMware                                ┃
┃ Application          ┃ Application Deployment                ┃
┃ Module               ┃ ADSModule                             ┃
┃ Running in Container ┃ No                                    ┃
┃ Current State        ┃ Indeterminate                         ┃
This is the cause: Docker 29.4.2 SteamCMD Issue
Thank you for letting me know it was a docker issue.
Here for anyone who may need to downgrade and are on Debian 13: BACKUP BEFORE DOING AND USE WITH CAUTION!!!
Downgrading Docker to 29.4.1 on Debian 13 (Trixie)
1. Stop Docker Services
Stop the daemon and sockets to prevent data corruption during the downgrade.
sudo systemctl stop docker.socket
2. Identify Exact Version String
Check the available versions in your repository to confirm the exact string (e.g., 5:29.4.1-1~debian.13~trixie).
apt-cache madison docker-ce
3. Run the Downgrade Command
Use the --allow-downgrades flag. Replace the version strings below if apt-cache showed a slightly different naming convention for your repo.
sudo apt-get install --allow-downgrades -y \
  docker-ce=5:29.4.1-1~debian.13~trixie \
  docker-ce-cli=5:29.4.1-1~debian.13~trixie \
  containerd.io \
  docker-buildx-plugin \
  docker-compose-plugin
4. Pin the Version
Prevent apt upgrade from automatically updating Docker back to the newer version.
sudo apt-mark hold docker-ce docker-ce-cli
5. Restart and Verify
sudo systemctl start docker
docker --version
How to Re-enable Updates (Unpinning)
If you later decide you want to upgrade Docker to the latest version again, follow these steps:
1. Remove the Hold
This tells apt that it is allowed to modify these packages again.
sudo apt-mark unhold docker-ce docker-ce-cli
2. Upgrade to Latest
Run a standard update and upgrade to pull the newest version available in the Debian 13 repos.
sudo apt-get update
sudo apt-get upgrade docker-ce docker-ce-cli
That certainly helped me, Thank you.
