| Field |
Value |
| Operating System |
| Product |
AMP ‘Deimos’ v2.7.0.0 (Mainline) |
| Virtualization |
Docker |
| Application |
Windrose |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Failed |
Cant boot up the Server. The Server needs a display to output the startupconsole.
i have tryed to add the “xvfb” Package in AMP for this Instance, but it did not help or i did it wrong. Maybe you can Check the Template.
- Upgrade AMP
- Load Container for Windrose
- Tryed 2 another version of WINE
- Added “xvfb” in this Instance
Issue is happening with mine as well, I’ve tried making multiple instances and even removed from container and it made no difference
Same issue for me. Also tried creating additional instances.
Seemingly the same issue for me. The error I get specifically in the console is wine: Unhandled illegal instruction at address 000000014147C7B8 (thread 0110), starting debugger…
If any of you are running AMP in a VM, eg in Proxmox, make sure the CPU mode on the VM is set to Host (might have a different name in another hypervisor)
May I ask if there’s going to be Windows version instance for noob like me? TIA.
It is already there. The server is windows native (only)
I’m sorry but I cannot see it on my list, or maybe I’m looking differently?
Restart AMP. Or fetch latest on the configuration repositories (use the search box if you can’t find that setting)
I got it now after updating instances. Thank you!
Anyone manage to get it to start on a linux Amp instance yet?
not me , been battling it since it got released. Logoutputdevice:error
