| Field |
Value |
| Operating System |
Windows - Windows 11 Pro on x86_64 |
| Product |
AMP ‘Deimos’ v2.7.2.0 (Mainline) |
| Virtualization |
Xen |
| Application |
Windrose |
| Module |
GenericModule |
| Running in Container |
No |
| Current State |
Installing |
NOt sure what is wrong with it, but I need it working.
- update, restarted instance, restarted entire server. fall failing.
- google didnt help
- dont want to lose my data
I currently have 5x Windrose servers running just fine on a linux system.
perhaps these steps can help you.
if your AMP repository is outdated, you might need to update it,
From ADS, go to Configuration → Instance Deployment → Instance Management
then under Configuration Repositories - click Fetch Latest
then retry your install.
make sure that World Island ID is filled in, ( you will find the ID using file manager - R5/Saved/SaveProfiles/Default/RocksDB/0.10.0/Worlds)
if this ID is not populated, it will create a new world each time the server is restarted.
i hope this helps
