the new instance just givea a CMD notification in the Console but doesn’t do anything else. The old server gives this error Update state (0x3) reconfiguring, progress: 0.00 (0 / 0)
Error! App ‘896660’ state is 0x606 after update job.
updated AMP
tried to update and/or start valheim both don’t work
tried to install a new instance but this doens’t work.
Issue: Failing to download/update Valheim server files.
I have tried uninstalling and re-installing the valheim server.
Tried updating the instance itself.
Tried running said server inside and out of docker container.
Verified plenty of HD space.
All failed.
Workaround… I manually downloaded the valheim server files and copied them into AMP. At this point AMP was able to launch and fully load the server and was able to successfully connect to it. It was also able to properly download and install the ValheimPlus mod and BepInEx, but still unable to download/update the server files themselves.
Conclusion: Either a bad steamCMD.exe file, bad script (steamscript.dat maybe?) or improper method of passing commands to steamCMD.exe.
EDIT: I also tried to edit the steamscript.dat file using a different method of downloading the server files, but every time I tried to install/update the server this file was replaced regardless of having “keep steamCMD scripts” enabled both in AMP and also in the valheim server config section.
I hope this additional info helps resolve this issue.
