Field | Value |
Operating System | Linux - Ubuntu 24.04.1 on aarch64 |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | QEMU_KVM |
Application | Valheim |
Module | GenericModule |
Running in Container | No |
Current State | Stopped |
After starting instance of Valheim, SteamCMD starts but doesn’t download and stuck at 1/7. Currently running on aarch64 and have CPx emulation turned on.
- Create instance
- select valheim
- click start
Deployment logs have mutliples of this line:
LIM - Failure to make API call to Valheim01: Connection refused (127.0.0.1:8085)
Valheim logs show this:
[07:40:36] [Program Info/1] : Starting AMP version 2.6.0.6 (Phobos), built 20/11/2024 20:57
[07:40:36] [Program Info/1] : Stream: Mainline / Release (aarch64) - built by CUBECODERS/buildbot on CCL-DEV
[07:40:37] [Program Info/1] : Running in a QEMU KVM environment.
[07:40:37] [Program Info/1] : OS: Linux / aarch64
[07:40:37] [Program Info/1] : CPU: ARM Neoverse-N1 (4C/4T)
[07:40:37] [Program Info/1] : RAM: 23980MB
[07:40:37] [Program Info/1] : AMP Instance ID: 58d1a34e-ab27-40e5-bfa4-9bc38950ca75
[07:40:37] [Core Info/1] : Loaded GenericModule version 2.6.0.6 by CubeCoders Limited
[07:40:37] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[07:40:37] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[07:40:37] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[07:40:37] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[07:40:38] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[07:40:38] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[07:40:38] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[07:40:38] [System Error/9] : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/Valheim01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[07:40:38] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[07:40:38] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[07:40:38] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[07:40:38] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[07:40:38] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[07:40:38] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
[07:40:38] [FileManager Notice/1] : Generated new keypair with fingerprint iIf/t2gHq0t+qiqP5C2EEIKuFc15pRgHWURXhlGclqo=
[07:40:38] [Loader Notice/1] : Using keypair with fingerprint iIf/t2gHq0t+qiqP5C2EEIKuFc15pRgHWURXhlGclqo=
[07:40:38] [Loader Info/1] : SFTP Server started on 0.0.0.0:2228
[07:40:39] [Core Info/1] : Webserver started on http://127.0.0.1:8085
[07:40:39] [System Info/10] : Checking for AMP updates…
[07:40:39] [System Info/9] : Startup mode is UpdateAndStart.
[07:40:40] [System Warning/15] : 2025/02/12 07:40:40 socat[1045471] W ioctl(6, TIOCSCTTY, NULL): Operation not permitted
[07:40:40] [System Warning/15] : 2025/02/12 07:40:40 socat[1045471] W tcsetpgrp(1045471): Inappropriate ioctl for device
Box86 with Dynarec v0.3.9 eaf2e84 built on Feb 8 2025 09:26:36
Looks like steam didn’t shutdown cleanly, scheduling immediate update check
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…
[07:40:40] [System Info/7] : AMP is up to date.
[07:46:22] [System Activity/18] : Authentication attempt for user willhpkns from 127.0.0.1
[07:46:22] [System Activity/17] : Authentication success
[07:51:06] [System Activity/15] : Authentication attempt for user willhpkns from 127.0.0.1
[07:51:06] [System Activity/20] : Authentication success
