Startup Issue with Valheim - Server does not work with crossplay enabled
Application Valheim
I activate crossplay and try to start the instance, it does not load and keeps displaying the following message in the log:
“PlayFab reconnect server ‘Timm’
Server ‘Timm’ begin PlayFab create and join network for server”
If you disable crossplay on the server it works and I can only connect on the desktop
  • Enter in configuration and enable crossplay
  • Start instance and wait
  • Check logs and try connect in steam/xbox
kkkkkkkkkkkkkk se deu mal
