| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | Docker |
| Application | Valheim |
| Module | GenericModule |
| Current State | Sleeping |
Whenever I perform a reboot on my server, it fails to restart the instances running through Docker. The error I receive is:
Startup failure: Docker returned error code 125
The logs provide the following details:
docker: Error response from daemon: Conflict. The container name “/AMP_Valheim01” is already in use by container “253cb184ef6a196f5e9316888f5e302e386800056b1b390b438832bea062c48a”. You have to remove (or rename) that container to be able to reuse that name.
My Valheim instance is set to start on boot.
Is there a way to auto start my docker instances after a reboot ? Because I need to manually restart the server after each reboot
- Run a server instance in a docker container
- Set it to auto start up on boot
- Reboot AMP Host machine
