| Operating System | Linux - Debian GNU/Linux 11 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | QEMU_KVM |
| Application | Valheim |
| Module | GenericModule |
| Running in Container | No |
| Current State | Failed |
mono runtime and class libraries are out of sync
- Update application
- Start application
- Fail err139
Logs :
Do not report this as a bug unless you’re sure you have updated correctly:
you probably have a broken mono install.
If you see other errors or faults after this message they are probably related
and you need to fix your mono install first.
cant resolve internal call to “System.MissingMemberException::FormatSignature” (tested without signature also)
Your mono runtime and class libraries are out of sync.
The out of sync library is: /home/amp/.ampdata/instances/Moriarti01/Valheim/896660/unstripped_corlib/mscorlib.dll
When you update one from git you need to update, compile and install
the other too.
cant resolve internal call to “System.Reflection.MemberInfo::get_MetadataToken” (tested without signature also)
the other too.
Caught fatal signal - signo:11 code:1 errno:0 addr:(nil)
Obtained 15 stack frames.
#0 0x007f750d469140 in funlockfile
#1 (nil) in (Unknown)
#2 0x00000041a6cbeb in (wrapper managed-to-native) Mono.SafeStringMarshal:StringToUtf8 (string)
#3 0x00000041a6cb03 in Mono.SafeStringMarshal:get_Value ()
#4 0x00000041a6ca43 in System.Environment:internalGetEnvironmentVariable (string)
#5 0x00000041a6c9bf in System.Environment:GetEnvironmentVariable (string)
#6 0x00000041a612a3 in System.TimeZoneInfo:CreateLocal ()
#7 0x00000041a60fe7 in System.TimeZoneInfo:get_Local ()
#8 0x00000041a60f77 in System.TimeZoneInfo:GetDateTimeNowUtcOffsetFromUtc (System.DateTime,bool&)
#9 0x00000041a6069b in System.DateTime:get_Now ()
#10 0x00000041a60203 in BepInEx.Preloader.Entrypoint:Main ()
#11 0x00000041a60610 in (wrapper runtime-invoke) object:runtime_invoke_void (object,intptr,intptr,intptr)
#12 0x007f750c47f3fe in mono_runtime_invoke
#13 0x007f750c4d970d in mono_gc_pending_finalizers
#14 0x007f750c19df60 in (Unknown)
