Startup:
Console12:18:16
[UnityMemory] Configuration Parameters - Can be set up in boot.config
"memorysetup-bucket-allocator-granularity=16"
"memorysetup-bucket-allocator-bucket-count=8"
"memorysetup-bucket-allocator-block-size=4194304"
"memorysetup-bucket-allocator-block-count=1"
"memorysetup-main-allocator-block-size=16777216"
"memorysetup-thread-allocator-block-size=16777216"
"memorysetup-gfx-main-allocator-block-size=16777216"
"memorysetup-gfx-thread-allocator-block-size=16777216"
"memorysetup-cache-allocator-block-size=4194304"
"memorysetup-typetree-allocator-block-size=2097152"
"memorysetup-profiler-bucket-allocator-granularity=16"
"memorysetup-profiler-bucket-allocator-bucket-count=8"
"memorysetup-profiler-bucket-allocator-block-size=4194304"
"memorysetup-profiler-bucket-allocator-block-count=1"
"memorysetup-profiler-allocator-block-size=16777216"
"memorysetup-profiler-editor-allocator-block-size=1048576"
"memorysetup-temp-allocator-size-main=4194304"
"memorysetup-job-temp-allocator-block-size=2097152"
"memorysetup-job-temp-allocator-block-size-background=1048576"
"memorysetup-job-temp-allocator-reduction-small-platforms=262144"
"memorysetup-temp-allocator-size-background-worker=32768"
"memorysetup-temp-allocator-size-job-worker=262144"
"memorysetup-temp-allocator-size-preload-manager=262144"
"memorysetup-temp-allocator-size-nav-mesh-worker=65536"
"memorysetup-temp-allocator-size-audio-worker=65536"
"memorysetup-temp-allocator-size-cloud-worker=32768"
"memorysetup-temp-allocator-size-gfx=262144"
Mono path[0] = 'D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/Managed'
Mono config path = 'D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/MonoBleedingEdge/etc'
Loading player data from D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/data.unity3d
Initialize engine version: 2021.3.19f1 (c9714fde33b6)
[Subsystems] Discovering subsystems at path D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/UnitySubsystems
Forcing GfxDevice: Null
GfxDevice: creating device client; threaded=0; jobified=0
NullGfxDevice:
Version: NULL 1.0 [1.0]
Renderer: Null Device
Vendor: Unity Technologies
FMOD failed to get number of drivers ... : "Error initializing output device. " (60)
FMOD initialized on nosound output
Begin MonoManager ReloadAssembly
12:18:24
- Completed reload, in 7.856 seconds
12:18:26
Microsoft Media Foundation video decoding to texture disabled: graphics device is Null, only Direct3D 11 and Direct3D 12 (only on desktop) are supported for hardware-accelerated video decoding.
12:18:27
UnloadTime: 3.977300 ms
Fallback handler could not load library D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/MonoBleedingEdge/data-0000022850304A40.dll
12:18:28
2023-07-17T12:18:28 1.141 INF Version: Alpha 21 (b324) Compatibility Version: Alpha 21, Build: WindowsPlayer 64 Bit
2023-07-17T12:18:28 1.145 INF System information:
2023-07-17T12:18:28 1.146 INF OS: Windows 10 (10.0.17763) 64bit
2023-07-17T12:18:28 1.146 INF CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz (cores: 24)
2023-07-17T12:18:28 1.147 INF RAM: 32757 MB
2023-07-17T12:18:28 1.147 INF GPU: Null Device (128 MB)
2023-07-17T12:18:28 1.158 INF Graphics API: NULL 1.0 [1.0] (shader level 5.0)
2023-07-17T12:18:28 1.158 INF Last played version: Alpha 19.5
2023-07-17T12:18:28 1.163 INF Local UTC offset: -4 hours
2023-07-17T12:18:28 1.206 INF Command line arguments: D:\AMPDataStore\Instances\SevenDaysToDie01\seven-days-to-die\294420\7DaysToDieServer.exe -quit -batchmode -nographics -configfile=seven-days-settings210.xml -dedicated
2023-07-17T12:18:28 1.231 INF Parsing server configfile: D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../seven-days-settings210.xml
2023-07-17T12:18:28 1.342 INF Parsing server configfile successfully completed
2023-07-17T12:18:28 1.347 INF Starting dedicated server level=Navezgane game name=My AMP Game
2023-07-17T12:18:28 1.347 INF Maximum allowed players: 8
2023-07-17T12:18:28 1.347 INF Game mode: GameModeSurvival
2023-07-17T12:18:28 1.350 INF [Platform] Init
2023-07-17T12:18:28 1.470 INF [Platform] Using native platform: Steam
2023-07-17T12:18:28 1.475 INF [Platform] Using cross platform: EOS
2023-07-17T12:18:28 1.475 INF [Platform] Using server platform: Steam
2023-07-17T12:18:28 1.475 INF [Platform] Using server platform: XBL
2023-07-17T12:18:28 1.484 INF Starting PlayerInputManager...
12:18:29
2023-07-17T12:18:29 2.036 INF InControl (version 1.8.2 build 9357, native module = False, XInput = False)
2023-07-17T12:18:29 2.082 INF [Platform] Initializing Steam
2023-07-17T12:18:29 2.083 INF [Platform] Initializing EOS
2023-07-17T12:18:29 2.312 INF [EOS] Initialize: Success
2023-07-17T12:18:29 2.429 INF [Platform] Initializing XBL
12:18:30
2023-07-17T12:18:30 3.099 INF Localization language from prefs: english
2023-07-17T12:18:30 3.100 INF Awake IsFocused: True
2023-07-17T12:18:30 3.884 INF Started Terminal Window
2023-07-17T12:18:30 3.884 INF Dedicated server only build
12:18:31
2023-07-17T12:18:31 3.972 INF Occlusion: Awake
2023-07-17T12:18:31 3.981 INF Texture quality is set to 3
2023-07-17T12:18:31 4.014 WRN Device name for flag StandaloneWindows is unknown
2023-07-17T12:18:31 4.275 INF WinThread started
2023-07-17T12:18:31 4.319 INF [MODS] Start loading from: 'D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../Mods'
2023-07-17T12:18:31 4.356 INF [MODS] Trying to load from folder: 'TFP_CommandExtensions'
2023-07-17T12:18:31 4.382 INF [MODS] Loaded Mod: TFP_CommandExtensions (21.0.318.0)
2023-07-17T12:18:31 4.383 INF [MODS] Trying to load from folder: 'TFP_MapRendering'
2023-07-17T12:18:31 4.396 INF [MODS] Loaded Mod: TFP_MapRendering (21.0.318.0)
2023-07-17T12:18:31 4.396 INF [MODS] Trying to load from folder: 'TFP_WebServer'
2023-07-17T12:18:31 4.403 INF [MODS] Loaded Mod: TFP_WebServer (21.0.318.0)
2023-07-17T12:18:31 4.403 INF [MODS] Trying to load from folder: 'Xample_MarkersMod'
2023-07-17T12:18:31 4.468 INF [MODS] Loaded Mod: TFP_MarkersExample (21.0.318.0)
2023-07-17T12:18:31 4.468 INF [MODS] Initializing mod code
2023-07-17T12:18:31 4.470 INF [MODS] Found ModAPI in CommandExtensions.dll, creating instance
2023-07-17T12:18:31 4.471 INF [MODS] Initialized code in mod 'TFP_CommandExtensions' from DLL 'CommandExtensions.dll'
2023-07-17T12:18:31 4.471 INF [MODS] Found ModAPI in MapRendering.dll, creating instance
2023-07-17T12:18:31 4.474 INF [MODS] Initialized code in mod 'TFP_MapRendering' from DLL 'MapRendering.dll'
2023-07-17T12:18:31 4.478 INF [MODS] Found ModAPI in WebServer.dll, creating instance
2023-07-17T12:18:31 4.501 INF [MODS] Initialized code in mod 'TFP_WebServer' from DLL 'WebServer.dll'
2023-07-17T12:18:31 4.502 INF [MODS] Found ModAPI in MarkersMod.dll, creating instance
2023-07-17T12:18:31 4.503 INF [MODS] Initialized code in mod 'TFP_MarkersExample' from DLL 'MarkersMod.dll'
2023-07-17T12:18:31 4.503 INF [MODS] Loading done
2023-07-17T12:18:31 4.544 INF Permissions file 'serveradmin.xml' not found, creating.
2023-07-17T12:18:31 4.620 INF Command "chunkcache" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.624 INF Command "createwebuser" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.627 INF Command "debugshot" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.627 INF Command "debugweather" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.628 INF Command "decomgr" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.632 INF Command "getgamepref" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.633 INF Command "getgamestat" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.633 INF Command "getlogpath" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.633 INF Command "getoptions" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.634 INF Command "gettime" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.635 INF Command "gfx" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.636 INF Command "graph" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.637 INF Command "help" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.641 INF Command "listplayerids" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.642 INF Command "listthreads" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.645 INF Command "memcl" has no explicit permission level, but a default permission of 1000, adding to permission list
2023-07-17T12:18:31 4.672 INF Command "settempunit" has no explicit permission level, but a default permission of 1000, adding to permission list
12:18:32
2023-07-17T12:18:32 5.308 INF Reloading serveradmin.xml
2023-07-17T12:18:32 5.309 INF Loading permissions file at 'D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../User/Saves/serveradmin.xml'
2023-07-17T12:18:32 5.330 INF Loading permissions file done.
12:18:34
Couldn't create a Convex Mesh from source mesh "Head" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
12:18:35
2023-07-17T12:18:35 8.731 INF Loaded (local): rwgmixer in 0.07
12:18:36
2023-07-17T12:18:36 9.216 INF Loaded (local): archetypes in 0.48
2023-07-17T12:18:36 9.235 INF Loaded (local): loadingscreen in 0.02
2023-07-17T12:18:36 9.238 INF WorldStaticData.Init() needed 3.000s
2023-07-17T12:18:36 9.346 INF Started Telnet on 27017
2023-07-17T12:18:36 9.369 INF [PartyQuests] Initialized
2023-07-17T12:18:36 9.370 INF Awake done in 6270 ms
12:18:39
2023-07-17T12:18:39 12.282 INF NET: Starting server protocols
GameStat.GameState = 0
GameStat.GlobalMessageToShow =
GameStat.IsCreativeMenuEnabled = False
GameStat.IsFlyingEnabled = False
GameStat.IsPlayerCollisionEnabled = True
GameStat.IsPlayerDamageEnabled = True
GameStat.IsResetMapOnRestart = False
GameStat.IsSaveSupplyCrates = True
GameStat.IsSpawnEnemies = True
GameStat.IsSpawnNearOtherPlayer = False
GameStat.IsTeleportEnabled = False
GameStat.IsVersionCheckDone = False
GameStat.LandClaimCount = 3
GameStat.LandClaimDeadZone = 30
GameStat.LandClaimDecayMode = 0
GameStat.LandClaimExpiryTime = 3
GameStat.LandClaimOfflineDelay = 0
GameStat.LandClaimOfflineDurabilityModifier = 32
GameStat.LandClaimOnlineDurabilityModifier = 32
GameStat.LandClaimSize = 41
GameStat.LoadScene =
GameStat.LootTimer =
GameStat.OptionsPOICulling = 0
GameStat.PartySharedKillRange = 100
GameStat.PlayerKillingMode = KillStrangersOnly
GameStat.ScoreDiedMultiplier = -5
GameStat.ScorePlayerKillMultiplier = 1
GameStat.ScoreZombieKillMultiplier = 1
GameStat.ShowAllPlayersOnMap = False
GameStat.ShowFriendPlayerOnMap = True
GameStat.ShowSpawnWindow = False
GameStat.ShowWindow =
GameStat.TimeLimitActive = False
GameStat.TimeLimitThisRound = 0
GameStat.TimeOfDayIncPerSec = 20
GameStat.TwitchBloodMoonAllowed = True
GameStat.UNUSED_ShowZombieCounter =
GameStat.XPMultiplier = 100
GameStat.ZombieHordeMeter = False
2023-07-17T12:18:39 12.853 INF StartAsServer
12:18:40
2023-07-17T12:18:40 13.546 INF Loaded (local): materials in 0.62
2023-07-17T12:18:40 13.796 INF Loaded (local): physicsbodies in 0.25
12:18:41
2023-07-17T12:18:41 13.996 INF Loaded (local): painting in 0.20
2023-07-17T12:18:41 14.519 INF Loaded (local): shapes in 0.52
12:19:15
2023-07-17T12:19:15 48.520 INF Telnet connection from: 127.0.0.1:55768
2023-07-17T12:19:15 48.522 INF Started thread TelnetClient_127.0.0.1:55768
Please enter password:
Logon successful.
*** Connected with 7DTD server.
*** Server version: Alpha 21 (b324) Compatibility Version: Alpha 21
*** Dedicated server only build
Server IP: Any
Server port: 27015
Max players: 8
World: Navezgane
Game name: My AMP Game
Difficulty: 2
Press 'help' to get a list of all commands. Press 'exit' to end session.
12:19:41
2023-07-17T12:19:41 74.917 INF Block IDs with mapping
Unloading 6 Unused Serialized files (Serialized files now loaded: 9)
12:19:42
2023-07-17T12:19:42 74.941 INF Block IDs total 22097, terr 29, last 22319
2023-07-17T12:19:42 74.986 INF Loaded (local): blocks in 60.47
12:19:43
Unloading 64428 unused Assets to reduce memory usage. Loaded Objects now: 64861.
Total: 1209.719500 ms (FindLiveObjects: 13.076600 ms CreateObjectMapping: 23.460900 ms MarkObjects: 1122.500900 ms DeleteObjects: 50.680600 ms)
2023-07-17T12:19:43 76.585 INF Loaded (local): progression in 1.60
12:19:45
2023-07-17T12:19:45 78.769 INF Loaded (local): buffs in 2.18
12:19:46
Xbox Trigger Effect: PistolTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: ShotgunTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.947 INF Xbox Trigger Effect: PistolTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: RifleTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.949 INF Xbox Trigger Effect: ShotgunTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.949 INF Xbox Trigger Effect: RifleTrigger effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: PistolShoot effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: ShotgunShoot effect(VibrationSingle): str(0.5),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: RifleShoot effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: PistolZoom effect(VibrationSingle): str(0.35),StartPosition(0),endPos(0),amplitude(0)
Xbox Trigger Effect: RifleZoom effect(VibrationSingle): str(0.65),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.949 INF Xbox Trigger Effect: PistolShoot effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.950 INF Xbox Trigger Effect: ShotgunShoot effect(VibrationSingle): str(0.5),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.950 INF Xbox Trigger Effect: RifleShoot effect(FeedbackSingle): str(0.8),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.950 INF Xbox Trigger Effect: PistolZoom effect(VibrationSingle): str(0.35),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.950 INF Xbox Trigger Effect: RifleZoom effect(VibrationSingle): str(0.65),StartPosition(0),endPos(0),amplitude(0)
2023-07-17T12:19:46 78.975 INF Loaded (local): misc in 0.21
12:19:47
2023-07-17T12:19:47 80.829 INF Loaded (local): items in 1.85
12:19:48
2023-07-17T12:19:48 81.183 INF Item IDs with mapping
2023-07-17T12:19:48 81.185 INF ItemIDs from Mapping
2023-07-17T12:19:48 81.378 INF Loaded (local): item_modifiers in 0.55
2023-07-17T12:19:48 81.846 INF Loaded (local): entityclasses in 0.47
12:19:49
2023-07-17T12:19:49 82.044 INF Loaded (local): qualityinfo in 0.20
2023-07-17T12:19:49 82.433 INF Loaded (local): sounds in 0.39
2023-07-17T12:19:49 82.682 INF Loaded (local): recipes in 0.25
2023-07-17T12:19:49 82.890 INF Loaded (local): blockplaceholders in 0.21
12:19:50
2023-07-17T12:19:50 83.247 INF Loaded (local): loot in 0.36
2023-07-17T12:19:50 83.495 INF Loaded (local): entitygroups in 0.25
2023-07-17T12:19:50 83.695 INF Loaded (local): utilityai in 0.20
2023-07-17T12:19:50 83.897 INF Loaded (local): vehicles in 0.20
12:19:51
2023-07-17T12:19:51 84.096 INF Loaded (local): rwgmixer in 0.20
2023-07-17T12:19:51 84.348 INF Loaded (local): weathersurvival in 0.25
2023-07-17T12:19:51 84.547 INF Loaded (local): archetypes in 0.20
2023-07-17T12:19:51 84.892 INF Loaded (local): quests in 0.34
12:19:52
2023-07-17T12:19:52 85.090 INF Loaded (local): traders in 0.20
2023-07-17T12:19:52 85.292 INF Loaded (local): npc in 0.20
2023-07-17T12:19:52 85.541 INF Loaded (local): dialogs in 0.25
2023-07-17T12:19:52 85.742 INF Loaded (local): ui_display in 0.20
12:19:53
2023-07-17T12:19:53 85.944 INF Loaded (local): nav_objects in 0.20
2023-07-17T12:19:53 86.191 INF Loaded (local): gamestages in 0.25
12:19:54
2023-07-17T12:19:54 87.107 INF Loaded (local): gameevents in 0.92
2023-07-17T12:19:54 87.465 INF Loaded (local): twitch in 0.36
2023-07-17T12:19:54 87.720 INF Loaded (local): twitch_events in 0.25
12:19:55
2023-07-17T12:19:55 88.005 INF Loaded (local): dmscontent in 0.29
2023-07-17T12:19:55 88.255 INF Loaded (local): XUi_Common/styles in 0.25
2023-07-17T12:19:55 88.505 INF Loaded (local): XUi_Common/controls in 0.25
2023-07-17T12:19:55 88.705 INF Loaded (local): XUi/styles in 0.20
2023-07-17T12:19:55 88.905 INF Loaded (local): XUi/controls in 0.20
12:19:56
2023-07-17T12:19:56 89.157 INF Loaded (local): XUi/windows in 0.25
2023-07-17T12:19:56 89.354 INF Loaded (local): XUi/xui in 0.20
2023-07-17T12:19:56 89.676 INF Loaded (local): biomes in 0.32
2023-07-17T12:19:56 89.877 INF Loaded (local): worldglobal in 0.20
12:19:57
2023-07-17T12:19:57 90.075 INF Loaded (local): spawning in 0.20
2023-07-17T12:19:57 90.275 INF Loaded (local): loadingscreen in 0.20
2023-07-17T12:19:57 90.429 INF createWorld: Navezgane, My AMP Game, GameModeSurvival
2023-07-17T12:19:57 90.431 INF Occlusion: Disabled
2023-07-17T12:19:57 90.520 INF Started thread ChunkRegeneration
2023-07-17T12:19:57 90.521 INF Started thread ChunkCalc
2023-07-17T12:19:57 90.522 INF Started thread ChunkMeshBake
2023-07-17T12:19:57 90.624 INF World.Load: Navezgane
2023-07-17T12:19:57 90.644 INF Loading base world file header...
2023-07-17T12:19:57 90.670 INF Loaded world file from different version: 'Alpha 22 (b19)'
2023-07-17T12:19:57 90.737 INF BloodMoon SetDay: day 7, last day 0, freq 7, range 0
2023-07-17T12:19:57 90.774 INF BloodMoon SetDay: day 7, last day 0, freq 7, range 0
2023-07-17T12:19:57 90.801 INF Started thread WaterSimulationApplyChanges
12:20:20
2023-07-17T12:20:20 113.738 INF Started thread GenerateChunks
12:20:22
2023-07-17T12:20:22 115.263 INF Calculating world hashes took 1446 ms (world size 189 MiB)
2023-07-17T12:20:22 115.658 INF Loading dtm raw file took 1889ms
12:20:23
2023-07-17T12:20:23 115.994 INF Biomes image size w= 3072, h = 3072
12:20:25
2023-07-17T12:20:25 118.030 INF Loading and creating biomes took 2370ms
12:20:28
2023-07-17T12:20:28 121.241 INF Loading and creating shader control textures took 3211ms
12:20:29
2023-07-17T12:20:29 122.753 INF Loading and parsing of generator took 1511ms
2023-07-17T12:20:29 122.837 INF Computed 401 chunk groups containing a total of 7813 chunks. Largest group contains 462 chunks.
2023-07-17T12:20:29 122.843 INF Started thread SaveChunks D:\AMPDataStore\Instances\SevenDaysToDie01\seven-days-to-die\294420\User\Saves\Navezgane\My AMP Game\Region
12:20:34
2023-07-17T12:20:34 127.682 INF [DECO] read
2023-07-17T12:20:34 127.730 INF Decorating chunks
12:20:36
2023-07-17T12:20:36 129.420 INF Dynamic Music Initialized on Server
2023-07-17T12:20:36 129.420 INF Dynamic Music Initialized on Dedi
2023-07-17T12:20:36 129.469 INF AstarManager Init
12:20:37
2023-07-17T12:20:37 130.772 INF WeatherManager: Init 8 weather packages
12:20:38
2023-07-17T12:20:38 131.283 INF createWorld() done
2023-07-17T12:20:38 131.291 INF Loading players.xml
2023-07-17T12:20:38 131.319 INF WeatherManager: ApplySavedPackages
2023-07-17T12:20:38 131.368 INF Loaded player
2023-07-17T12:20:38 131.806 INF [EOS] Registering server
12:20:39
2023-07-17T12:20:39 132.475 ERR [Steamworks.NET] Could not initialize GameServer
2023-07-17T12:20:39 132.475 INF Loading dymesh settings
2023-07-17T12:20:39 132.477 INF Dynamic Mesh Settings
2023-07-17T12:20:39 132.478 INF Use Imposter Values: False
2023-07-17T12:20:39 132.478 INF Only Player Areas: True
2023-07-17T12:20:39 132.478 INF Player Area Buffer: 3
2023-07-17T12:20:39 132.478 INF Max View Distance: 1000
2023-07-17T12:20:39 132.479 INF Regen all on new world: False
2023-07-17T12:20:39 132.491 INF Dymesh: Prepping dynamic mesh. Resend Default: True
2023-07-17T12:20:39 132.491 INF Dymesh: Mesh location: D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../User/Saves/Navezgane/My AMP Game/DynamicMeshes/
2023-07-17T12:20:39 132.551 INF [Web] Webserver not started, WebDashboardEnabled set to false
2023-07-17T12:20:39 132.552 INF StartGame done
2023-07-17T12:20:39 132.924 INF [EOS] Server registered, session: 2e992a733c6a4d1882ee3ad3342bdc02
12:20:40
2023-07-17T12:20:40 132.940 INF [EOS] Session address: 192.159.209.168
2023-07-17T12:20:40 133.266 INF Dymesh: Warming dynamic mesh
2023-07-17T12:20:40 133.266 INF Dymesh: Creating dynamic mesh manager
2023-07-17T12:20:40 133.281 INF Dymesh: Awake
2023-07-17T12:20:40 133.282 INF Dymesh: Mesh location: D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../User/Saves/Navezgane/My AMP Game/DynamicMeshes/
2023-07-17T12:20:40 133.286 INF Dymesh: Loading Items: D:/AMPDataStore/Instances/SevenDaysToDie01/seven-days-to-die/294420/7DaysToDieServer_Data/../User/Saves/Navezgane/My AMP Game/DynamicMeshes/
2023-07-17T12:20:40 133.293 INF Dymesh: Loaded Items: 0
2023-07-17T12:20:40 133.299 INF Dymesh: Loading all items took: 0.0139894 seconds.
2023-07-17T12:20:40 133.319 INF Clearing queues.
2023-07-17T12:20:40 133.320 INF Cleared queues.
2023-07-17T12:20:40 133.324 INF Dynamic thread starting
2023-07-17T12:20:40 133.333 INF Dymesh door replacement: imposterBlock
Connection attempt:
Could not retrieve server ID
I see the server on the list, IP address shows as my external (even tried to connect via internal)
