Startup Issue with V Rising - V Rising Server Instance
Application V Rising
Server wont startup shows error in the log: run app with -diag-job-temp-memory-leak-validation
  • Migrate save to this instance
  • Edit Server Game and host Settings
  • Start Server
I might have the same issue since an update, the servers seems to be running though if i type ‘help’ in console it responds. Although connecting is not possible.
Yeah It seems to be running but not able to connect as well, AMP is showing to be constantly trying to start the server and never reaching a “Started” state.
Ik fixed it by updating the server, stopping the server, save the network settings for the instance and starting again. Hope it works for you aswell. :slight_smile:
No Luck on that, still cant get the server to load. Side note I cant see any options to change the Ports, When I Search for the option it doesnt exist.
